Laguna 3000 series bandsaws
Terry
I am looking for an 18 inch band sawn to do a lot of resawing. I am a serious hobbiest. One that I am considering is the Laguna LT18 3000. Is anyone experienced with one of these? How do they compare to the original LT18?
Re: Laguna 3000 series bandsaws
an alternate view
Bill Tindall
If that is the saw I am thinking it is , the saw has a dinky table. Why band saws are made with dinky tables is a mystery to me. I find that a band saw with a large table is more convenient to use for about anything a band saw is used for.
Used Delta 20" saws, and their Powermatic equivalent, are commonly available and they have a much larger table. They were a mainstay of commercial shops for decades. The only thing that can be wrong with them are bearings and tires. The seemingly small but hefty 1 HP motor that is common on them has never slowed down for any resawing I have done.
Re: an alternate view *LINK*
charlie belden
The specs on the 3000 series units show a 20"x20" table, with rack & pinion tilt mechanism and 17" from blade to upright housing the blade at the rear of the unit.
It's easy to make a larger table if it's needed. I made one inspired by an American Woodworker idea (see attached link). It has an auxilliary table that can be put in front of the blade or behind the blade or to the outside of the blade. I seldom find a need for using it, and, in a shop with limited space, it's handy to only put it on when needed and then put it away afterwards.
A one horsepower motor on a bandsaw that's used primarily for cutting flat stock and ply with a half inch or maybe even a 3/4" blade is more than adequate. But if 12" stock is to be resawn, even with a good sharp blade, 1 hp means slower feed rate - and likely some or more burn marks - than a 2, 2 1/2 or 3 hp motor.
Making a larger table is much cheaper than replacing a motor with a more powerful one - and you can make one specific for your needs.
shop made tables for bandsaw
GolfSteve in Calgary
I wasn't going to post because I've never used a 3000 series bandsaw, but since there's so few responses I'll post my observations.
I own an older LT18 (before they raised the resaw height, added ceramic guides, increased the motor size, and added the rack and pinion table adjustment). It is a very heavy saw, 475 lbs from memory. The newer LT18 resaw master fixes a number of things that were small deficiencies in the original LT18.
My local woodworking store has an 18" 3000 series bandsaw for sale, so I've only seen it but never used it and can't comment on its performance.
In general I'd say the 3000 series construction is noticeably lighter than the LT18. The frame is lighter/smaller, the wheels are lighter, the table is smaller and lighter, and the fence is smaller and kind of dinky.
On the plus side, perhaps the table is flat (my LT18 table was not very flat), and the price is lower than the LT18.
You say you do some "serious resawing"....if I had the money I would go for the LT18 over the 3000 series.
ps. on my older LT18 there were a number of problems that I hope are fixed in the current model:
1. The table dipped towards the center so you couldn't get a square cut from both sides of the blade. I ended up buying a replacement table.
2. The lower Carter style guide could be adjusted far enough back to use smaller blades < 1/4"
3. The electrical connections for the power cord were overtorqued and one of the power leads was broken. I bought the saw used and do not know who installed the power cord.
