What does a Big Boy Band Saw cost?
I have been fiddling with my 14" Delta band saw with Riser from day one and am tired of it. What bandsaw would you recommend for resawing? Would like to be able to reliably take veneer slices up to 12" wide. Don't want to spend a lot of time setting it up over and over and finding the drift angle and what all. Want to set it up with an excellent blade and use a fence, not a point fence. Any suggestions?
Re: What does a Big Boy Band Saw cost?
MiniMax 18" or 20" - figure $3K delivered (could be low- haven't checked)
Laguna same size, about the same.
Felder - more
I have the MM 16 - capacity 16 wide and deep, 4.8 HP use use up to 1 1/4" blade. Mine cost about $2400 delivered about 4 years ago. Think new one is around $2900 list now. I'm prejudiced but I think its one of the best built. Does more than I will ever need.
Ken Oakley-Sunny St. Cloud, FL
When one of the Robber Barons, maybe John J. Astor, was asked how much it cost to operate his yacht, his reply was--" if you have to ask, you can't afford one".
Dave Paine
Barry,
I have a Grizzly 17in G053 (if I am recalling the model number correctly).
I think this has the capability. The bigger issue feels to me to be tuning and blade.
I purchased a Highland Woodslicer and initially got a thin veneer from an 8in wide piece of black walnut. After some other cuts, this was not reproduced. I am predicting the blade had dulled.
I think the tuning is not difficult, but the blade makes the difference. I am now considering getting a blade from Supercutbandsaw to see if this will allow me to make the same veneers you want to cut.
Other choices
Rikon 18" 10-345 runs about $1500. 2 1/2 hp, will cut to about 12". 240 V.
Jet runs about $1750-1900.
General runs about $2500.
I've got a Rikon and I'm quite happy with it.
Friend has an original 18" Rikon
Ray - Middletown, IN
that we played with and consistantly got .010 veneer, sheet after sheet. We had less than .003 variation across the sheet. As I recall they were about 8" wide cherry.
Ray
Yet another choice...
doug f, san clemente, ca
Barry - I got an Aggazanni 18" about three years ago at a show. IIRC it was about $2,500, probably more now. A 1/2" Woodslicer has produced 1/16" veneers from 10" black walnut consistently.
Something else to consider.
Doug
Jet 18" 3 HP
Pat Evans
I got my 18" Jet in '07 for less than $1400. Does everything I need and I find the guides easier to set than a Rikon.
Re: Jet 18" 3 HP
Clementine
One of the major sponsors here is General. If it were me (and it's not), I would use toolseeker.com to help with comparisons. Then I would come back here and look closely at the General. I have their contractors table saw and it is a fine piece of machinery.
John M in Mid Mich
I have a Laguna LT 16 (more of a "medium boy", but with 3hp). Rip a LOT of large stock and am impressed. Have done a bit of veneer, but that isn't my main deal. I generally work from rough cut air dried lumber, and often find myself using oversized stock (say 5/4) to generate my desired end product (say 3/4") because that is the board I have, and the dimension I want. I'll usually slice off a 1/4" slab so as not to make it into chips on the planer. And then I have slabs of 1/4" stock to make boxes or whatever. I invested in some good carbide tipped blades from Laguna, too. It is exercise to put a 10-11 inch thick block through the saw, but the results are quite good. I also do a fair amount of green/wet stock if I come upon something interesting (most recently some American Hornbeam ca. 10" diameter). My budget was such that I could have gone with a truly brutish beast, but my decision process on picking the LT 16 was something like: "capacity for some bigger stuff, but not so big I can't do finer/curvier cuts." If you go too big, you may find yourself wishing for a second smaller bandsaw for fine cuts, and my shop is too small for two bandsaws.
Re: What does a Big Boy Band Saw cost? *LINK*
Phil Smith
See attached link to pleasant street machinery for good idea of what a used middle wt. to heavy wt. bandsaw will cost. Looks like range is about $ 1000 to $8000. I've been to pleasant street machinery and he has lots of nice stuff.
Once you use one of the big bandsaws you will be spoiled.
http://www.pleasantstmachinery.com/index.php?mact=Gallery,m6e73e,default,1&m6e73edir=Saws%2FBandsaws&m6e73ereturnid=19&page=19
