unisaw question
unisaw question
unisaw question
tom b
My unisaw has a problem, I assume with the switch. I turn it on, the blade starts to spin, but the motor does not keep running. As long as I hold the button, the motor stays on, but if I release the on button, the motor stops. Any ideas out there. Thank you.
Re: unisaw question
Re: unisaw question
Robby Wright in San Marcos, CA
Tom - It sounds like the holding contacts of the magnetic starter aren't working properly. The contacts are supposed to keep the coil connected to power once the start button is released. If the contacts aren't working correctly, you will get exactly the symptom you describe.
Robby Wright
Re: unisaw question
Dale Lenz
Would blowing the switch out w/ air help?
Re: unisaw question
Re: unisaw question
Don Evans
READ ALL BEFORE BEGINNING TO DO ANYTHING
They supply 2 different switches with the unisaw, a GPE and a LVC but I believe, not positive that both are magnetic switches.
The very first THING YOU DO IS UNPLUG THE A/C POWER CORD FROM OUTLET, DO IT NOW, NOT LATER.
It would be interesting to know later if the green ON button is round or square?
AFTER you have the power UNPLUGGED you can open the black box with the on/off switch on it.
This is much easier if I knew if you know how a relay works? I'll assume you don't or you would not be on here asking about this. Anyway, you can blow out box with air if you see saw dust in there but it is pretty sealed so not sure that is problem.
There are several sets of contacts to a mag switch and when you push the button in, the GREEN ON ONE, all of the contacts move away from the at rest position and make contact with another set of contacts. One pair of them does nothing but apply power to the coil that holds the contacts in the same position that you moved them too with the button. If that one set of contacts is not making good contact then the contacts will spring back as soon as you release the green button stopping the motor.
This is how it gets its name, it is just an electromagnet that when energized holds the contacts in one direction. The off button is wired in to this one set of contacts also and pressing it opens the connection so power cannot get through the holding contact and on to the coil and the relay (switch) releases and the contacts are pulled back to rest position by springs.
So there are 3 things, one is bad contact on that holding set, broken wire on the holding set, or a bad OFF button.
Also check the RED off button and make sure it is released see if it has arrows on it showing it turns CW to release it.
Now that you have read this through before doing anything MAKE SURE THAT MACHINE IS UNPLUGGED!!!
If you don't understand ANY part of this, stop and call electrician or Delta repair.
Don
Re: unisaw question
Re: unisaw question
Alan in Little Washington (NC)
Do you have an all-in-on mag starter switch or a low voltage control with buttons on the front of the saw and a relay box on the back? They work similarly, except the latching circuit on the all-in-one units runs at the motor voltage while the low voltage controls work on 24 volts.
In addition to what Dale and Robby said, make sure the wiring to and from the stop button is intact and securely connected to the button switch and relay terminals. Also, make sure the stop button is mechanically full out. It has normally closed contacts so when you push it in you open the contacts and break the relay latching circuit. If it is stuck in a little the contacts will always be open and the saw will only run if you push and hold the start button.
Re: unisaw question
Re: unisaw question
Don Evans
Hey Alan, you were 4 minutes slower.... wonder how many people on here know what little washington is besides you and me?
I'm just outside Clayton but raised about 6 mile outta Greenville on RT43 going SE.
Don
Re: unisaw question
Re: unisaw question
Rod Rentz
Had the same problem on a General jointer. I took the easy way out and just replaced the switch. About $20.
