Crib-Builders Question
I'm starting construction design work on a crib. Basic design is chosen, but I've a question on mattress suspension.
I know that I can get a steel spring platform ready-made, but am wondering if anyone has used a true platform instead. I can make a nicely rigid platform in MDF and then fix it to the crib ends with "L" brackets bolted to threaded inserts or an inlayed steel bar drilled/tapped at intervals. Makes it pretty simple to change the height of the mattress as the child grows, and gives better support to the mattress.
What say Yee'all?
M
Re: Crib-Builders Question
Bill Tindall
Kids weigh next to nothing. I can't imagine that it matters what is under the mattress. I always use a piece of plywood, but I didn't arrive at this choice as a result of any scientific investigation.
Kneale Brownson
Kneale Brownson
I too have used plywood, varnished well so it can be cleaned.
Alan in Little Washington (NC)
I'm getting ready to start a baby set too, so went looking at cribs at Babies R Us- pretty crappy stuff, including the chests, most especially the drawers!
The style of crib my son and his wife are looking at had brackets and/or steel or hardwood rails attached to the corner posts running across the front and back that supported a sheet of MDF and the mattress. There was nothing running front to back at the ends (short sides) of the crib, however, so the thin (1/2"? 3/8" ?) MDF was already sagging there with nothing but the weight of the mattress on it. I imagine the sagging could be worse by the time the baby is ready to transition to the toddler day bed- I'm making a 3 - 1 convertible bed.
As I see it, an MDF board is definitely out. I will likely use support rails across the front, back AND along both sides to support a sheet of good birch ply.
The BRU crib had 4 sets of mounting holes (with threaded inserts?) in the corner posts which allowed 4 different mattress heights. I think the holes also provide a place to attach long side rails when you convert the crib to a regular bed.
Thanks Gents
Was considering MDF for the finished edge, but have decided to edge band good ply with hardwood to match the crib, then use some 1x1 angle iron on the short sides to take the hanger straps.
Fixed rails (no drop-side) will be 30" tall so I plan 5 positions spaced at 4" intervals for the height adjustment. That gets outgrown and Granpa'll be makin' a Big Boy/Girl bed anyway. :D
Waiting to see if they choose to have an 8" folding top section on the front rail-set.
This is fun!
An endless project list
Bill Tindall
After the beds comes some furniture to put clothes in, toy chest (make it so it can become a hope chest), jewelry box , desk and later a dining table, coffee tables, chairs, etc, etc.
Hope So
After all, "I make stuff."
:D
