Removal of finish and glue from metal surfaces
Bill Tindall
Wife has been cleaning various adhesives from my collection of putty knives and spatulas. She even got well cured contact cement off a spatula. How'd you do that?
She said she was just soaking these things in boiling water and after a while the stuff softened and off it came. Well I thought.....I have a cup for a spray gun that has years of conversion varnish cured to it. The stuff cross links and solvent doesn't touch it, which is what makes it so hard to thoroughly clean after use.
She put it in a pot and boiled it for a couple of hours and off it all came, to my astonishment. I am not sure what is going on but it works.
I know they clean glue from the clamp racks in furniture factories with steam lines.
Re: Removal of finish and glue from metal surfaces
Jason Roehl in Lafayette, IN
I would guess that the heat has something to do with it--not just softening the material, but causing the metal to expand enough to break the mechanical bond the finish has to it.
I've found alternating hot and cold water on paint roller pans and cut buckets can cause the tougher stuff to pop off.
Jason
Re: Wow!! That Gal's a keeper, Treat her nice!
Heat....
Howard Acheson
.... is the magic stuff. Very few finishes and adhesives can withstand heat above 150-170 degrees. It causes the finish to soften and it either loses adhesion or is quite easy to rub or scrape off.
I used to use an infrared heat lamp on my paint gun cans but boiling water seems like a better idea.
Just saw a This Old House episode where they visited a shop that recycles old doors and such. They were cleaning up old hardware by soaking it in a Crock Pot for a couple of hours and the paint just pealed off.
Sort of a Hmmm? moment for me. I have been remodeling houses lately and usually replace the Plated brass butt hinges on the doors just to brighten them up. I just spent about fifty bucks on the current house. Maybe I should take the old Crock Pot to the job and soak them?
what seems to be important.....
Bill Tindall
So far wife's technique has rescued numerous spatulas and scrapers, the cup for my spray gun, tips for glue bottles, and two holders for 3M PPS spray cups, $$$$. What seems to be important is the combination of heat and water. As soon as the object cools and dries the finish re-hardens. While hot and wet the finish can be scraped or wire brushed off.
One might investigate additives to see if the effect can be enhanced. One might try vinegar, ammonia, dishwasher detergent, Simple Green, ???? However, basic additivesl such as ammonia may attack aluminum.
Vinegar....
Howard Acheson
... has been used in conjunction with hot water for years to loosen hide glues and non-waterproof adhesives. It will work with PVA adhesive but it won't work with Type I adhesives like Titebond III.
Heat, whether supplied by hot water or some other source, will even soften epoxy adhesives so that the joint can be opened.
