Recommendation for Drill Press
JERRY DRAPER
I need to replace my drill press. I have read the drill press reviews in FWW. Delta drill presses are out of stock and will not be available until March. I am considering a Rigid DP 1550. I have never had a Rigid product. Does anyone out there have experience with this product? Any other recommendations in the $500 price range?
Re: Recommendation for Drill Press
What are going to be doing with your drill press??
Do you need power? A lot of quill travel? What are your specific needs? Or is it just a general all-around drill press?
The Ridgid has a 3 3/4" quill travel and a 1/2 hp motor. Not too bad. The Rikon and the Jet 17" drill presses have more powerful motors and the Jet 17" has a longer quill travel. I put sanding drums on my drill press. The extra hp seems to help. I also bore some long holes once in a while, so the longer quill travel definitely helps.
Jason Waters
I have a Jet Shopline 14" floor drill press. It came with a 1/3 hp motor. I bought it for $150 on closeout (It's no longer made). It is a good drill press. Here are the things I wish it had:
longer stroke, it's only like 3.5" or so, it would be nice if it was longer.
depth stop rod. It has the locking spinning dial thing behind the levers to lower the quill. I'm used to it now, but it's not so easy to get an exact depth.
A bigger motor. I solved this one this year with a 3/4 hp motor off my bandsaw when I upgraded it.
Variable speed, not using pulleys I have to adjust all the time. I solved this with said motor above and a Variable Frequency Drive ($100).
The crank handle broke, is was plastic with a metal insert. I reworked it and welded on a metal handle. Looks cheesy, works great, for 7-8 years now.
That's a pretty expensive drill press with all that stuff, but it was cheap and little of here and there, and I did the work.
I've not looked at the Ridgid closely, so I can't comment on that specifc one.
Here are some things to consider:
I'd look for one with the quill travel you want, at least a 1/2 hp, but really a 3/4 hp motor (true 3/4), and a drilling depth you can live with (my 14" has generally been fine, a few times I couldn't use it.)
As to the motor hp, compare the amps, my Jet 1/3 had almost the same amp draw as the old (like year 2000) Grizzly 3/4 hp motors. I have heard Grizzly has really improved their equipment, so you might want to look there.
The variable speed is really nice, but it's out of reach of most budgets, or too involved for most people to convert like I did. The Powermatic for like $1000 has it all, but I have read mixed user reviews of it. That's why I decided to do what I did (and it was cheap). I lived 10-12 years without it....
Despite all the shortcomings above I mentioned, it has been one of the most used tools in my shop. My point is you really need a drill press, and in my opinion, a floor one (though there are some nice tabletop ones now). Look on craigslist, etc. My father picked up a store name (from like Tractor Supply or something) for like $75 at a yard sale. It was about like my Jet, a little rougher, but a heck of a value.
The point about using it as a sanding drum, I will say bigger motor is better. I used to use mine like that until I got a BOSS Sander. And it bogged down with a 2" drum and the 1/3 hp motor.
del schisler
i have that drill press and find it work's for me. Their are some that cost more and may have a few more thing's on it. Just figure out what it will be used for. I use mine in the wood shop . I haven't found anything i couldn't do with it. I guess if you wanted to drill a 4" hole it wouldn't do that unless you turned wood aroung with a 3 1/2" travel. Look at the Home depot's and see if thay may have one out of the box or one on desplay that they would sell cheeper ?? I bought mine out of the box but the box was their for $150.00 a good deal . Check creig list for item close their may be someting in their. I belive you would be happy with it. They have a life time warrenty on it also.
Henry (Raleigh, NC)
I too have a Ridgid floor model drill press - bought used locally. I would guess the model # is that one you listed. It is my first DP and it has done what I have needed in lathe related work or in making furniture.
I am a 'buy used and make it work' sort of person rather than a 'buy the latest model with all the features and a 100,000 mile warranty' person, especially for a utilitarian piece of equipment like a DP.
I'm happy with mine, and have not had any issues with it. I can't really compare to other current models either.
Henry
Thanks for the info. - very helpful.
