Re: Recommendation for drum sander requested *LINK*
Dave Paine
Bill,
I have a Performax 16in drum sander. I would likely not buy this again. It may be me, but the items I sand are narrower in the middle than the ends, and I try REALLY hard to avoid this.
I also have a Flat Master, see link. If you want ease of changing abrasives, this is the way to go. Barry Irby re-configuired his Performax to try a similar arrangement.
The big benefit is almost zero heat when sanding, so you could even sand off finishes.
I find I am able to get a much flatter surface with this unit than my Performax.
They also sell kits, so you could likely build your own frame.
Note the price does not include motor. I bought my motor from Grizzly.
If you do stick with a drum sander, I recommend the blue ziron abrasive from Klinspor. It does not generate as much heat, so less gumming up. So far I get a LOT more use from this abrasive than the Klingspor regular abrasive which came with the unit.
http://www.stockroomsupply.ca/shop/drum-sanders.html
