*** SURVEY: THE IDES OF JANUARY *** *LINK*
Okay, so I missed the Ides by a week. That only means you need to respond sooner if you want your comment to appear in the next edition of Woodworker West magazine.
In talking with Ron Goldman, editor of Woodworker West, recently, we mused about the role of mistakes in woodworking. Sometimes they are nothing but a nuisance, but other times, they can not only be instructive, but they can lead to entire new ways of doing things. This month, I'd like to hear about your relationship to your mistakes. Do you fix them? Do you make "details" out of them? Have you ever learned something you hadn't expected, and even applied that new awareness to other projects?
It's all about mistakes, folks. We all make them. The question is, what do we make of them?
As usual, your answers will be run through our editorial blender and sent off to appear in the March/April issue of Woodworker West. I appreciate your input as usual.
Cheers,
Ellis Walentine, Host
Woodworker West Magazine
Re: *** SURVEY: THE IDES OF JANUARY *** *LINK*
Dave Paine
Ellis,
Good topic. I expect there are two types of Woodworkers, those who have mad e mistakes, and those who will.
I am in the first camp.
I try to recover from my mistakes in a manner where the result looks like an intended design.
I have many such examples, but not easy to find pictures.
I posted pictures of a Craftsman inspired board over the Xmas holidays. You gave a favourable comment. This piece had an inlay of curly maple. I was doing a resaw of a piece of 8in curly maple. The bandsaw blade went off course. I had some big cut-outs. I glued the pieces together and patched in the offcut. The assembly laid gathering dust for over a year.
For the recent board I wanted to include this piece. The grain pattern was very attractive. I ended up cutting off the patch. I now had a piece which was not wide enough for the project. I ended up added two pieces of curly black walnut. The overall width was greater than the maple slab. So I ended up gluing 3/8in pieces of white oak to the maple, just to avoid having to cut the attractive curly black walnut to width.
I have many other examples, but this illustrates my desire to turn a mistake into a design feature. In this case, the recipient was very happy.
Stuart Hough
I try the CSI route...dig into what went wrong and how to eliminate the possibility in future work. Then I work on figuring out how to salvage the piece. Example of this was the picture frame I made for a special poster. I was running the stock across the router table and tarried a bit in one spot while I repositioned my hands for the rest of the cut. The router bit made a divot in the frame. I almost tossed the piece of maple, but then it hit me that I could take the other parts of the frame that were finished and "bump" them against the spining bit in a random way and I would have a frame with a bit of "interest". Needless to say, the LOML loved it.
Bill Tindall
1. I never turn a mistake into a "design element". My objection may derive from an inability to be sufficiently creative to do so, or it may simply be that the style of stuff I make doesn't lend itself to adding such features.
2. Success in woodworking depends on the ability to recover from mistakes or misjudgements in design.
3. Experience has not lessened my mistake frequency. As I gained more experience I made more complex stuff providing new opportunity for screw-ups.
paul in AZ
Mistakes happen. All too regularly.
There are times when the only recourse is to start over but a source of satisfaction is in disguising them.
A good eg. is a sloppy dovetail. I can now tighten a sloppy dovetail with slivers of matching wood that can be noticed only if you look very closely.
charlie belden
Mistakes - assuming they don't involve bleeding or unconsiousness - are always opportunities.
One can learn what NOT TO DO the next time. In this case, when taking apart a tight, dry fit mortise and tenon joint - keep your face away from where the tenoned part will go when it finally does come loose.
One can figure out a way to repair the mistake.
One can seize an opportunity to exploit a mistake and make it into a previously unforseen design opportunity and convert it into an feature.
or
One can cuss and swear, calm down - and make another piece - the RIGHT way. Then come up with a means of insuring that THAT mistake isn't repeated (the Triangle Parts Marking System, The Mark The Waste Side System, the Think Twice, Cut Once Method, The Test Your Finish On Scrap FIRST Method, the Leave The Line, Take The Line or Split The Line Method, . . .)
paul in AZ
Charlie: My last table was a coffee table in maple where I thought I'd glue up 3/4" to => 6/4 legs. The glue line didn't look wonderful so I ran it through the table saw along the glue line and inlaid walnut strips. It wound up looking good enough to keep. Racing stripes.
Ray Carson - Lawrenceville, NJ
Mistakes...well....usually when that happens, it involves a bit of profanity and an occasional throwing of tools. Albeit, since my tools are of better quality these days that doesn't happen too often. :) I'm somewhat of a profectionist and this is probably why mistakes get me so irritated.
Mistakes usually happen when I'm tired and pushing to get a lot done in a short amount of time. If it's an easy "do-over", then I will correct it. If I'm too far along I will try and hide it or mirror the mistake on an adjacent side to make it look intentional.
This may include inlays, fillers, plugs, etc. of a contrasting wood or if it's in a really visible place, a wood and grain pattern to match the original.
NickinMass
I wish that I could make mistakes that could be converted into design "features" - most of my mistakes seem to be of the nonrecoverable type (fence not tight, board cut too short, etc.), so I have to replace the workpiece. Of course, the last mistake I made (mortise on the wrong layout mark) was repaired to be invisible and will never be spoken of again...
Mike Circo
Rather than explain the fixes, I'd like to visit my reactions.
Many years ago, just two days before a trip to Disney World with my two young sons, I decided I HAD to finish something in the shop. So I hustled through my planned project, it's getting a bit late and I made the inevitable mistake. Furious at my stupidity I stormed around the shop beside myself with anger and kicked an "empty" storage bin.
Empty in quotes because it was filled with cutoffs and scrap for the fire pit and weighed a ton. I thought I had broken my toe. The pain was bad, but more painful was the thought that I wouldn't be able to enjoy the Disney waterparks and hiking with my family.
Fortunately a trip to the doc the next day showed only a sprain and I was hobbled, but okay for the trip.
To this day, I treat a mistake with less anger, less fuss and little concern. Its only wood, its fixable, and as we've seen, the fix may make the piece even more beautiful.
The final word...Sitting here many years later, I can not recall what the mistake was, nor even what the project was!!!
