OT Garage floors
Mike Farinella
I'm looking for a product to remove floor stains (engine oil, rust, pets, etc.) in a home re-hab I'm doing. I plan to ultimately rent a pressure washer.
Thanks for recommendations.
OT Garage floors
Mike Farinella
Re: OT Garage floors
Don Orr
TSP-trisodium phosphate-used to be the standard. I don't know if it is even available any more. There should be special solutions designed for use with pressure washers availble at your local hardware or big box stores. I have one for decks that you spray on with the low pressure nozzle. let sit, and high pressure spray off. I'd be careful where the fluids go if you push them outside-like near flower beds or similar. Might not be good for them.
Jim Breeden
I would think a high pressure washer would spray whatever you will be using all over the walls, etc. Six mil plastic to protect the walls?
I like TSP - but phosphates down the sewer are an environmental no-no.
I have used clay kitty litter and kerosene to "draw out" most of the oil. I've followed it by applications of a paste of laundry detergent and dish soap.
It typically takes a couple of applications of the kitty litter and kerosene (spritz some kerosene and follow it with kitty litter).
Lee Schierer McKean, PA
You can spray the oil stains with Gunk Engine cleaner, let it set for 20-30 minutes and them pressure wash it. It might take two applications.
Lee
www.zepcommercial.com
wooden leg
Amway used to have some great stuff for cleaning concrete. Dave
paul in AZ
I've also used engine degreaser on concrete with success. Just hose it off well or you are right back where you started.
This recipe works very well.....
Tim Greif - West of Chicago
Oddly enough, WD40 is your friend for stubborn oil stains. I start by spraying the oil stains liberally with WD40. Use a stiff scrub brush to work it in well and let it sit for a while. Respray and scrub some more. You can soak up the goo with some kitty litter or paper towels. Then apply Gunk GP degreaser (or any other kind) and scrub that too. Pressure wash everything and you're good to go, at least for the oil stains.
Rust stains require a chemical treatment. I've neve had much luck with anything. There's qa laundry product called Whink, but that can get a bit spendy if you have alot of stains. I've never had any luck with CLR.
Alex Grigoriev
When you clean it a bit, coat it with the rustoleum epoxy paint.
