correctly sharpening lathe tools
Rich
Have two grinders, one with fine white stone which turns at high rpm. The other one from Grisley mfg. a slow rpm. with very fine stone and water dispensed on wheel. Instructions when viewed with Grisley unit shows grinding tools with wheel movement away from grind . I've been told running against the entended grind is the only way to acheive a sharp tool. Which direction should the wheel address tool? THANKS, Rich
