Case for Bike?
Case for Bike?
Case for Bike?
Thomas Norton
My wife and I are cyclists and we ride a tandem. Our tandem has couplings on it that allow it to be disassemble for travel. There are cases/suitcases that are available but they are a bit pricey.
I was wondering about building cases out of ? maybe 1/4" ply with fiberglass re-enforcement?
Any thoughts?
Re: Case for Bike?
Pricey indeed.
Gary Smyth
I checked on line. I found a fiberboard hard case held by cloth belts for a tandem bicycle selling for $400. Others found are nylon soft cases and range from $600 to $1100.00. Huh!!! I say do a bunch of noodling and some doodling and by all means build the case. If you use a ply skin over a glued and screwed 1 x 1, or smaller size (pocket hole?) frame you can build the box easily enough. You can use better hardware for security and ease of access. You might have to build out certain sections for hinges, lifting handles and tie downs. The interior can then be fitted to accommodate wheels, frame, sprocket/pedals and handlebars (if they can’t be turned 90 degrees), maybe a small parts /tool kit. Where are you going to put this? Exterior of the car – roof, or interior as with an SUV? The difference is weatherproofing. If exterior, I’d look to the West system epoxy and follow the same steps that you would to water proof a lap strake canoe. It will take same space, get messy and the weight will grow with each layer, but you can build it and insert shaped blocks so that everything fits perfectly in the container. If you don’t have the materials or tools the price will probably reach close to $300 with the cost of hardware and epoxy, but you can have the right transport for THAT bike. If you change bikes often, you will have to do it all again for the new bike.
It will take more time than maybe you have for the container to be completed as you will have to wait for the epoxy to set and be sanded several times, maybe add your custom paint. Still, I think it a terrific adventure to see how compact, light, and fitted for all the essentials and accessories you can make the container. Go for it.
Re: Case for Bike?
Re: Case for Bike?
John M in Mid Mich
We have an S&S coupled tandem that we take to Europe sometimes. It originally fit a 26" x 26" x 14" single case, but then the airlines reduced the size limit to total 62", and so I needed a second case. Faced with same conclusion as you: expensive, I built 2 new cases as you suggest. My design goal included being no heavier than the commercial unit. One is of 1/4 ply with fiberglass/epoxy inside and out. Shown in the attached pic. Used redwood for the framing, piano hinge and brass latches. Came out very classy. The second one I built like a strip canoe. 1/4" x 2" strips of redwood with cove profiles on the edges; same frame, epoxy and glass. This one looks way cooler, but I haven't needed to use it since I was able to cut down the original case (shown in foreground). This pic is packing up after 2 weeks in Tuscany. The airline goons have been able to do damage, however, and if I redesigned, I would try to find a way to strengthen the interface between the top and bottom pieces. Some interlocking aluminum profile like in the foreground case would be a big improvement. I haven't found this profile yet. I'd be happy to share more experience and details if you want.
Re: Case for Bike?
Re: Case for Bike?
Thomas Norton
John,
Who would've guessed that I would connect with a fellow Tandem Rider who also does woodworking!
Thanks for the info.
BTW what kind of tandem do you ride? We have a Co-Motion Speedster.
Re: Case for Bike?
Re: Case for Bike?
Thomas Norton
John,
Could you send me your email?
Tnorton770@gmail.com
Re: Case for Bike?
Re: Case for Bike?
John M in Mid Mich
Hey, tandems/woodworking - what doesn't fit there?
Ride a custom Erickson. He is a Seattle builder well known regionally and with a certain following nationally, though I understand he has stopped building. He does still lead tours in France, Spain and Italy for connoisseurs of fine bike touring. We have toured with him in 2002 Provence, 2003 Dordogne, 2007 Tuscany, 2010 Spain, and signed up for a redux 2012 in Provence. Tuscany and Spain both using my homemade case. The case suffered some pretty serious goon-age this last trip, and I will either make some significant upgrades, or buy another commercial case. Note that Erickson sells the S&S cases at the best price anywhere. Last time I talked to Nancy (ecycletours.com) she quoted something like $250.
John
