Spraying house paint questions
Anybody got experience spraying interior paint for houses?
Is this a good process? Significantly better than rolling? Faster? Easier? What about masking off stuff like windows?
Is there a brand or sprayer that you would recommend? Brand or type of paint? How bad is clean up and maintenance?
I am remodeling houses and basically both my son and I hate painting. Looking for a way to make it more palatable.
Re: Spraying house paint questions
Stuart Johnson
Barry, I share your hatred toward painting so I used a Graco airless paint sprayer when I painted my wife's sewing studio. This was a newly constructed empty room and took one coat of Kilz and one coat of paint. It went much faster than rolling.
Good:
1. Easy set up and cleaning.
2. Very easy to use with good coverage.
3. Made ceiling a snap with the wand extension.
4. Much faster.
Bad:
1. A lot of paint in the air so you must cover or mask everything you don't want to paint.
2. Used way more paint than rolling.
3. A lot of over spray on the unfinished floor.
Recommendation:
1. Rent one and give it a try before spending the money.
2. Figure on spending more prep time than painting time.
3. Paint before flooring or cover entire floor with paint tarps.
4. Take very good care in paint settings and thinning. (see #2 under bad).
5. Wear dust mask and safety glasses.
I think the excess amount of paint and over spray were operator error in proper setting and thinning. This can be overcome with experience. We do plan on painting the rest of the house interior this year (yeah :b ) but will prep and spray one small bedroom first to see how it goes.
Carol Reed, Pahrump, NV
Power roller for much more control, less prep and clean-up.
Stuart Johnson
I've used a power roller but didn't care for it. For whatever reason (probably because I hate painting so much) I did not get good coverage. Plus, we have popcorn ceiling texture in the house and when I've rolled it in the past is was a mess. I agree less prep.
One of the first things I plan on doing when we win the lottery is hire a painter and go on vacation until the job is done. Until then I will continue trying to convince my wife the worn, slightly soiled paint is a French antique paint scheme that would cost thousands to replicate.
Nat Robison
I've never done it myself but I have a builder friend who has done it on new builds. It seems to me that it's better suited to new construction before floor, trim, and finished electrical go in. As stated previously, I think you spend far more time in prep that painting........I personally like painting over prep so probably wouldn't choose this route.
Randy Johnson
My shop is about 30X30. It started life as a very neglected two car garage. Due to a number of factors, it is WAY out of square. Because of this, installing the drywall on the ceiling was a real nightmare. I screwed 1X4s on every seam to help make sure the ceiling stayed on the ceiling. Painting around all those 1Xs would have been a major, time consuming pain. Spraying seemed to be the best solution.
I painted before installing any lights and with only one receptacle installed. The panel cover was removed and a piece of cardboard used in its place. From start to finish, the four eight foot walls and ceiling took about 45 minutes per coat.
I did the outside of the shop this year. Prep took quite a while because it is aluminum siding, but the actual painting took less than two hours.
I’ve put on a lot of paint in my life with a brush and roller. Spraying is THE way to go if at all possible.
From what I’ve seen when the pros spray inside on new construction, overspray on the floors can be held to near zero. You will just have to get the hang of letting off on the trigger at the right time.
Bill Earl
It is the way to go for new construction/major renovations. Otherwise, the prep-time will consume any time you save in the actual painting. Nevertheless, for the even matte finish you get on ceilings it is worth it. For priming and ceiling work, an airless sprayer is the way to go. For trim, I use a Badger 400 touch-up gun.
Mark Nowicki
I have a Lemmer 1600, their cheapest airless sprayer (about $ 500) It is a Canadian brand, another popular brand seems to be Graco.
I use it to spray my Mom's rentals, (two bedrooms, living room, foyer, kitchen, including the inside of upper and lower cabinets, five closets, four doors). One coat of primer, two coats of finish, white latex. Sometimes I roll the final coat to even things out.The apartments are about 700 sq.ft.
Prep takes about two hours. I put Kraft paper on the floor ( 36" wide rolls) tape the edges down with painters tape. I place tarps on top of the paper, remove all doors and hardware, all cabinet doors, the covers off all plugs and switches, tape the switches and plugs, wrap plastic bags around light fixtures.
Weather permitting, I take the sashes out of the windows, otherwise I have a window washing kit and I wash off the over spray before it dries. Latex washes off glass easily even when dry.
I wear disposable overalls with a hood, a respirator and safety goggles, latex gloves.
Cleanup is easy, first with water, then the water gets flushed out with Var-sol which remains in the sprayer.
Spraying is faster if you are doing a whole house , same color, with lots of nooks and crannies. For smaller jobs it is six or half a dozen.
It is more fun though.
Mark
Bill Hagen
Like everyone else said, prep takes more time, unless you want everything painted. Clean-up also take longer. You also use more paint, because of the over spray and cleanup.
I used an airless sprayer to paint a houses worth of trim (painted before installing it) and to paint all the interior raised panel doors (25 give or take). Painting with a brush would have taken much longer and not had as nice of results. There was no prep other then figuring out how to paint all the doors in one day and how to let them dry when they are wet on all sides. (moving a soild MDF that has wet painted on all sides requires two people. i spent less time painting them moving doors around. Maybe 4 minutes to paint two doors at a time. And then 15 minutes to move and set up the next two.
Interior work I would roll unless its new or completely redone and there is not going to be much masking. and then i would probably only prime.
TomD
If one knows the pro tricks for using a roller, a regular on is all you really need. The main tricks are how to get point efficiently from whatever container you are using; lead with the open side of the roller. Roll of excess end paint in areas still to be covered. Use a long handle whenever possible, etc...
The biggest deal with exterior paint is prep. It needs to be about 95% of the job. Once the paint starts coming off, you pretty much need to go to bare wood, or at the least remove all but the most solid and easy to adhere to paint f a compatible type.
I would use a high volume low pressure sprayer, however they were using something I hadn't see before on TOH. I wouldn't waste time with a Wagner type deal. They do work but the paint goes on too thin, and there is a ton of blow back.
http://video.pbs.org/video/2181588989
It is part 6 of the episode: On the Rght Path. He says he only sprays primer and first coat.
