chairs
chairs
chairs
Joseph Mulherin
Cut out all of the parts for the chair on my bandsaw using the patterns I made first.
Then went to setup my planer on the Shopsmith and discoverdd I did not have the
proper socket for the planer shaft...so had to order it as well as some more 12"sanding discs.
Measured and drilled out the holes in the rockiers and arms for the spindles.
After I use the planer to get the correct thickness on the back and splats I plan on setting up the
lathe duplicator and lathe out the spindles using the patterns I have on hand from other projects..
Always saved my patterns to use like this from other projectSeat has been hogged out vut not finished sanding yet to get shape coved out to my satisfaction.....is really going to be an experience for me to do this, but the first chair is going well so far....next 5 will be easier....then the writing desk chair.
Re: chairs
Re: chairs
Joseph Mulherin
Have traced out the seat outline on the 2x6 boards, hogged out various depths with Fortsner bits...1" to 1/4" in front;
Setup bandsaw with new 1/2" blade and cut out the seat outline, then set the table to 45 deg. and cut off the bottom of the seat all around...was not hard at all and it will be easy to sculpture later.
Used the Saburr donut to sand off the edges of the seat for the slope needed...came out very nice and smooth, now shall smooth out more with ROS.
Will setup drill and drill out the holes for the spindles for the arms and then turn over the seat and drill out the legs at 17x6 deg.
Routered the arms and rockers with 1/2" roundover bit, drilled holes in them for spindles already.
After planing the seat back design and splats to 3/8" I shall setup the lathe duplicator and run the spindles to the patterns I have already.
Everything is going smoothly for me with no major problems so far.
Need to have someone tell me how to make and send pictures of my work to this WoodCentral for the rest of you to see. Have two cameras to use....Kodak 340 and Nikon Coolpix L24
Re: chairs
Re: chairs
Joseph Mulherin
Finished up using the Saburr carbide donut on seat; then mixed up some of the sawdust with Titebond glue to a peanut butter consistancy and smeared it around the seat on some marks to make everything sort of level. Tested it and the mixture has setup nicely...ready for the ROS final shaping and smoothing.
Cut some blocks at the 17x10 deg. slope for the legs and will drill the leg holes out Monday.
All parts have been cut and routed and sanded...just waiting for the planer drive socket to arrive from Shopsmith so I can do the seat back pieces down to 7/16-3/8". Also have to make a new steam box.
Will do final assembly dry to make sure things fit and the chair "sits well"...old Shaker proverb...
Re: chairs
Re: chairs
Joseph Mulherin
Watched Charles Neil on YouTube about using his table saw with dado blades to scorp out the chair seat...
nice and clean. Have two seats I will try his method on. Using the Fortsner bits and Saburr donut worked but I think his idea is really better.
Re: chairs
Re: chairs
Joseph Mulherin
tried using my 6" dado set but Shopsmith tables hit the top of the motor, so ordered a new 8" set, and am making a outlet rear table to be mounted on an adjustable roller stand. this will allow me to cut thru the dado blades and not drop off the rear of the table with the spacer tabs Charles Neil suggested
Watch his presentation on YouTube and you will see he has come up with a very good seat scorping methiod. YouTube/charles Neil/ seat sculpting
