Veritas - Innovation in Tools
Moving my Shop
Moving my Shop
Moving my Shop
Jim O, Davenport IA
My wife and I will be moving from Iowa back to Pennsylvania this year. We are building a new home and shop. I have not yet decided whether to move all my stationary tools or sell them and start over. There are pros and cons each way. Either way the tools will be relocated either to my new shop or someone else's.
My question -- Are there any special steps I need to take (other than basic teardown and packing) to ensure they are ready to survive the move? I'm most concerned about the cabinet saw, drill press and jointer.
If I move them to PA, they will probably be in storage for 4-6 months.
Thanks
Jim
Re: Moving my Shop
Jim DeLaney, Austintown, Ohio
Re: Moving my Shop
I moved my shop from California to Ohio - used Allied Van Lines, btw.
I let the movers handle all the power tools, but ahead of time I removed the fence and blade from the Shop Fox cabinet saw, and took the fence off the Delta joiner. The drill presses (2), both bandsaws (14" & 16"), and 15" Delta planer were all shipped 'as is.'
Everything arrived in Ohio without incident, and when I put the fence and blade back on the cabinet saw, it was still perfectly aligned. The jointer fence required re-squaring it to the table. The bandsaws, after I re-tensioned the blades were both great, and the DPs and planer were fine 'as is' as well.
All-in-all, it was a great move (other than being expensive!). Nothing at all - house or shop - was damaged, and everything was delivered when they'd promised it.
BTW, I also shipped my truck, rather than driving it. At the van lines' guy's recommendation, I used Dependable Auto Shippers (DAS) and it turned out to be cheaper than it would've been for me to have driven it cross- country, when you factor in meals, lodging and fuel. I even cheated a bit and loaded the truck bed with some lumber under the tonneau. ;-)
Re: Moving my Shop
Re: Moving my Shop
While only moving across town my situation was similar. I needed to move my tools but also store them until the workshop was built. I decided to go with a POD.
I knew I would want access to a lot of hand tools and hand held power tools for working on the new house and shop so I packed them in boxes and moved them outside of the POD. Once the shop was completed I just opened the pod and rolled the tools right into the shop.
Just one idea.
Tom
Re: Moving my Shop
Re: Moving my Shop
Bill Tindall
When I moved my stationary power tools I didn't do anything to prepare them. They were the most robust items on the truck. Well, actually I did remove the wings from the table saw.
Depending on where the items will be stored you might consider coating the ground surfaces with Boshield and a sheet of some sort of paper, or slip a plastic bag over the tool to keep the Boshield from rubbing off.
Re: Moving my Shop
Re: Moving my Shop
Jim O, Davenport IA
Do I need to relax the tension on the belts?
Re: Moving my Shop
Re: Moving my Shop
Pete in Holland MI
1) Remove anything that is loose and could get lost (rip fence, miter gauge, throat inserts, wrenches, etc) and park in a box.
2) Coil up power cords and secure with tie wraps
3) Blow out all the dust (courtesy thing)
4) With masking tape & a marker, write any notes as to "lift here", or "don't lift here", "do not lay down", "lay down on this side" to help the movers move effecively
5) Secure any adjustable features with their normal clamps
6) Be there and watch the movers move the machines, giving advice where needed.
7) Moving trucks ride much smoother than your pick-up, especially when loaded. Provided the machines are carried properly, and lashed down properly, they will survive the ride well.
Re: Moving my Shop
Build shop first
Ronster
Build the shop before you move for at least four reasons:
- shops are fun and helpful
- shops take time to set up after they're built
- your tools need a home
- if you build the house first or concurrently, it might deprive your shop of funds -- got to have priorities!
Re: Moving my Shop
Re: Build shop first
Jim O, Davenport IA
Unfortunately I can't. The new shop will be in the walkout basement. On the plus side, it will be 18 x 60 (3 times the size of my current shop) plus two large side rooms. Any suggestions for soundproofing the ceiling. I will have 16" trusses overhead.
Re: Moving my Shop
Why soundproof?
neal in San Jose
Do you think the sounds of your wife cooking and cleaning upstairs will bother you that much?
Re: Moving my Shop
Soundproofing
John in NM
I'm assuming you don't want to glue eggcrate foam all over the ceiling :D
Insulate between the trusses, that will help.
There are products you can use to isolate the ceiling drywall from the trusses, you could look into those. I believe they are just steel ribs that limit contact area. You can also double up the drywall, that is supposed to help keep the sheet from acting as a soundboard. Bottom one vibrates with the sound of your planer hacking off 1/4" of white oak, but only part of that vibration is transmitted to the sheet above. You can also put up a sheet of drywall, then screw 1x2 sleepers to the truss bottoms through the drywall, and then put another sheet of drywall over (errr..... under) the sleepers.
Re: Moving my Shop
Guillaume Dery
Speaking from experience (currently building my second basement shop), I can reccomend 3 things to really cut down on noise transmission.
1. Acoustic insulation batts between the joists. I am very fond of the Roxul safe n' sound which is a mineral wool insulation rather than figerglass. It's hydrofuge, fireproof and cuts with a breadknife. It also does not tear or sag. I am not sure if you guys have Roxul stateside but if so, it's great stuff!
2. Cheaper than the resilient channels, you can staple some foam gasket (the stuff you put under your 2X4s when framing a basement) to your joist edges prior to installing the drywall. This acts as a vibration dampener/absorber.
3. Double drywall
If you aren't sharing the basement, then you are set. If you are, you probably want to stagger-stud your dividing wall and fill that with Roxul too.
Another side note, depending on funds, if your back is as unfriendly as mine, you may want to consider doing something about the concrete floor. I just laid down 1" 4X8 XPS foam sheets, all joints taped and laid a 3/4" chipboard sub-floor on top if it, tapconned into the slab (all joints offset and staggered natch). This also helps to control moisture in the shop.
Good luck and I am way jealous of your shop space!!!
Guillaume
Re: Moving my Shop
Agree
Bill Tindall
I read the post quickly and didn't catch the new house construction. By all means build the shop first. The shop will go up in a week and provide a home for the tools and yourself to participate in the house construction. I can think of all sorts of additional benefits of having a closed dry work area on site. The house builders will love it to work in and storage even if you aren't doing part of the construction.
Re: Moving my Shop
Jim O, Davenport IA
Thanks for the tips - I have plans to put a plywood raised floor. I almost forgot to allow for the raised floor when I finalized the specs for the walkout door in the concrete foundation.
We can get Roxul. If I can still afford it when the time comes, I plan on using it. I've seen it used quite a bit on the DIY/Homeowner TV shows.
I'm looking forward to the space, not sure how I'm going to lay it out, but I have to decide soon for the electrical plan so we can get our permit. Trouble with that much space (compared to what I'm used to) is that there are so many possibilities. CAD layout software does help a lot, but it also makes it too easy to change my mind.
Re: Moving my Shop
Guillaume Dery
Just be careful. Multiple kinds of Roxul. ComfortBatt is for insulating and they put the R rating on the packaging. SafeNSound is formulated specifically for soundproofing (which is why they don't give you the R-value on the packaging).
No such thing as too much electrical. It's a bitch to add later. I am a fan or outlets every 4 feet (20 AMP split circuits, probably 2 runs in a shop as large as yours, giving you 80 AMPS to pull) plus outlets/circuits for the machinery. May also think about the height of your outlets. putting them over 40" saves you from bending down whenever you plug something in or of having to relocate them if some cabinets or machinery move in front of them.
Of course, the irony is that, after figuring all of this out, I became more of a handtool woodworker...
