Laguna Tools' Resaw King Bandsaw Blade
charlie belden
What DO you call the band with teeth that a bandsaw uses to cut wood?
Torbin, the president and owner of Laguna Tools is a bandsaw phreak. He enjoys slicing a see through, paper thin piece off a 12" wide board. He did, and perhaps still does, a lot of resawing to make bent laminate pieces. Not satisfied with bandsaw blades on the market, he designed his own, certain that it'd do what he needed a bandsaw to do. As president of the company, he was able to have his idea actually made. Worked as he expected and he added the Resaw King to his product line - originally at about $3 per inch of blade. Over time the price came down - a little - but still prohibitively expensive, at least for me. My bandsaw uses a 130" band
Laguna Tools had a Special on their original Resaw King carbide tipped bandsaw blades. The normal price was about $2.50 and inch so $75 for a 3/4" x 130" for my bandsaw was too good a deal to pass up. That was a year ago, and until today, it was still in the box I got it in.
Now I've done some thin resawing with a Wood Slicer and thought the sawn surfaces were pretty good. But I sometimes had to plane a sawn face flat before the next cut. Figured that was to be expected at times.
The results I'm getting from the Resaw King is impressive - can't tell the original planed surface on the board from the sawn surface - and the carbide teeth allow a faster feed rate than the Wood Slicer.
Checking LT's site, the Resaw King is now normally $1.73 per inch, but they've got a 25% off deal going. Not as good as about 60 cents per inch, but better than $2.50 an inch. If you've got some really nice figured wood - and want to stretch it by slicing it up into bookmatched thick (1/8") veneer - say for a piece of furniture, or a guitar top . . .
Re: Laguna Tools' Resaw King Bandsaw Blade
Torbin should send you a free one after this post
I met Torbin last year and he gave Ellis and me a demo. I was impressed. But I was hoping to hear from a woodworker. Thanks for that info.
Tom
Michael Wilkins
Agree 100% with your assessment of the blade. The cost is up there in the clouds, but for resawing hardwoods on a large bandsaw, it is great. The Woodslicer blade was on my Delta 14" machine but it was sold after getting a Laguna LT18 back in 2001. Got my Resaw King with the ceramic guide upgrade as a package deal, with great savings. Aside from the occasional sparks from the guides (which is harmless), this was a worthwhile upgrade. Now the bandsaws come standard with the ceramic guides.
Jim DeLaney, Austintown, Ohio
I've had a Resaw King on my LT-16 for a year or so, and continue to be amazed every time I use it. Near perfect cuts every time. I've resawn everything from pine 2 X 12 up to 6/4 Bloodwood, and a bunch of stuff in between. If you wanna cut your own veneers, this is the blade you want!
Re: Torbin should send you a free one after this p
charlie belden
Other than owning a Robland X-31 combi, an LT-16 SEC bandsaw and of course a Resaw King, all bought from LT, I have no connection with LT. I paid the going price for what I've bought from them - so my opinions on these things are just that - my opinions - based on my experience with them. Your mileage may vary - as the ads always say at the end of commercials ; ).
How does this compare to the Lenox Trimaster?
Bruce, a MN Galoot
I've had one for several years and have been pleased with its performance, but I'm always interested in the competition.
Plus, after a long time of looking, I've found a place in New York that resharpens carbide-tipped bandsaw blades.
straightening bent blades
GolfSteve in Calgary
I bought a used LT18 that came with 3 resaw king blades that I knew were damaged. On all three the carbide teeth were in good shape, but the blades had somehow become bent (the blades may have broke, then were rewelded, but a bend or bends were put into the blade somehow). One blade had a rather bad joint.
Is there a way to straighten out the bend in the blade? I tried putting these blades on the saw, but they are not usable in their current state (the bends cause the blade to jump as they pass through my Carter style guides).
The blades are pretty heavy. I think two are 1" blades and the other is 1-1/4". The blades feel like spring steel, and I think I would have trouble bending them into straightness, but I have not tried.
Perhaps I simply need to spend 40 years as an apprentice to a Japanese blacksmith to learn how to flatten a hand saw blade.
Re: straightening bent blades
Why don't you send The blades back to Laguna or the manufacturer and have them cut out and repair/replace the damaged sections? Can't imagine it would be significantly expensive compared to the cost of those blades.
Bill Tindall
call the blade manufacturer and ask to speak with tech service about this problem. They may be able to recommend a shop that can fix them. That failing, call Misenheimer in Morristown ,TN and ask there.
Thanks, Charlie!
Bruce, a MN Galoot
I have a TriMaster that I got for nothing (long story), which increases its value substantially. But I'm always on the prowl for whatever's next.
