OT-internet connection problems
Nat Robison
I've been having problems with intermittent internet connectivity and have some basic questions.....
I have Comcast for TV and hi-speed internet. The TV signal never goes out. Are the signals for hi-speed and TV the same? i.e. Is the signal getting to the house just fine, and the problem is between the splitter and the computer....or with the router?
My comber router/modem is about 5 months old. Info online says that most people with my problem state they can't get software updates for the modem. Motorola (modem maker) says Comcast must issue and Comcast won't issue since the modem isn't rented from them, although it's on their "approved" list.
I think my connections are all fine. Anyone else in the same boat?
Re: OT-internet connection problems
Jim Breeden
Nat....I have the exact problem you have with Comcast. I sent them an email explaining "their" problem, and their web connection/server sucks. :b Of course, they sent me in return a five page :b disertation on what I should do to improve MY connection! Formost, is their suggestion that I change my browser to accept their connection. WHAT? I have Internet 9 and Google, what else is there that is better? Tried Bling.......that also sucks. :b Last week, Comcast WAS having problems with their server.....what a mess. At first I thought it was on my end, tried everything, then discovered it was them! I emailed, and asked, "Why can't you provide an explanation as to why your server is down, i.e., maintenance, bird on a wire, lightening, etc, etc, etc". Never received a response. Typical large corp we got you by the . . . . . . answer - none!
There are other options
Lee Schierer McKean, PA
Call comcast and tell them you want to terminate your account and switch to directv or some other local provider. They will be far more friendly and most like change your rate to a lower one and maybe even connect you to tech support to get your connection problem sorted out.
It worked for my daughter.
Lee
Don Evans
Jim I'm not familiar with Comcast, but I'm curious to what means would they have to tell you there is a technical problem? Isn't the problem killing email? Would they have to telephone all their customers?
Not trying to be cute or curt here I just don't understand how they could have told you.
Don
Jim Breeden
Don.....With all their expertise in the tech world, they could put a mesage on their site, when it is pulled up, they are having a problem with the server, and are trying to correct the problem asap. Can't understand how this would be such an enormous problem for them.
Use to have the same issue…
Jim Rahbe, Bedford TX
Nat,
I had the identical problem with my ComCast cable. Internet was intermittent, but the TV never went out. Replaced the modem, but still had the same result. Sometimes you could log on the Internet and sometimes you couldn’t, usually at peak times. ComCast sent out a tech who knew what he was doing and he measured the actual signal levels. He added a two way power amp in the attic, and I’ve never had a problem since. This is not one of those amps you buy at Radio Shack, it is build specifically for the cable industry. It is special in that most amps will not allow signals to pass both upstream and down, this one will.
Call them and tell them you want one.
Jim R.
Re:  Have the same issue…
Jim Breeden
The thing is . . . . . Going to the Comcast home page is not the problem. When opening the computer, I go directly to Comcast. Trying to get past the home page is the problem. The latest incident last week was . . .click on email and I received a window, "Internet Explorer is not available at this time". Thinking my computer had lost IE9, I went into the system to find out why - no luck. Then I tried all sites - Google, Yahoo, Bling, etc - all the same message. That's when I contacted Comcast direct (strange, didn't need server to do that), and they had a message on their end that they were having a mechanical problem with the server. And, this is not the first time! I requested they put a note on the home page explaining the problem, then all us non-teckies out here would know it was not our computer that was screwed up. Simple request? - Guess not. >(
Kurt
I'm not expert, I don't play one on TV and I haven't stayed at a Holiday Inn Express lately. Having said that, I might try a different DNS server. We have FiOS which has been excellent but I'm still using Open DNS. Open DNS has security benefits as well
http://www.opendns.com/
How to change your DNS in WinXP: http://www.mediacollege.com/computer/network/dns.html
How to change your DNS in Win7: http://www.sevenforums.com/tutorials/15037-dns-addressing-how-change-windows-7-a.html
Re:  changing servers
Jim Breeden
Ya think Comcast will let me get away with it? :|
Jim Breeden
Knot to push a dead horse with a live cart...but...I received an email from Comcast asking me what server I am using. Huh? If they don't know, how am I supposed to know? :b
kurt
I don't know how Comcast works but were it me, I'd write down what the settings are now, change them to openDNS' I.P. addresses, reboot and see if it's any better. Because you wrote down the Comcast settings you should be able to restore what you have now. Google has DNS servers as well. I didn't use them because I figured Google knows enough about me as it is, they don't need to know more.
