We value your privacy.
The "dance studio" is above the lobby on the 2nd floor. There is a wall between the "dance studio" and the upper part of the auditorium above the suspended ceiling in the auditorium.
What would be a reasonable (and inexpensive way) to provide some sound insulation? There is a wall with 2 x 4 studs and wallboard on the dance studio side. There are just bare studs on the auditorium side.
Building a second wall with studs spaced in between the studs in the existing wall, but not touching. Inter weave sound deadening insulation between the studs, drywall the new stud wall on the auditorium side. Make sure there are no openings in either wall and no gaps in the insulation.
you can get "sound barrier board" inexpensively at good lumberyards. It's basically homasote, fluffy fibrous board. If you've got the room, you could add that to the audience side of your second wall.
If you don't have the space to do the second wall Lee suggests, an alternative would be to shoot foam into the stud bays of the existing wall and use sound barrier board.
I've never priced it, but there's also a sheetrock that's claimed to be the equal of eight layers of conventional sheetrock, as far as sound transmission. I betcha it's pricey; but you could check with commercial sheetrock suppliers who sell to civilians.
I find myself wondering, though, how much noise is transmitting through the joists - below the floor. Can you hear the dancers from the lobby?
The dance studio extends the full width of the interior (68') and is easily 18' from front to back. It also has pine floors, a mirrored area on one of the walls, etc.
I don't know if it is a factor below the floor joists. I know there is some sound transmission down to the lobby, but we probably won't have people there during the evening rehearsals. The floor of the dance studio is poured concrete slabs with a layer of 2" thick pine boards as flooring.
I'll look for the sound barrier boards. I can take out a couple of ceiling tiles and boost it on up there (if it isn't too heavy). Drywall is out. That would be a real PITA to get up.
It can be 1 1/2" or maybe more in thickness and because it is fiber doesn't weigh that much - I'm guessing 25 lbs, a sheet. It works better than nothing, but to do it right there needs to be a sealed mass (no breaks or intrusions) and it ought to be isolated from the sound source.
