sand blasting
Jim Canning
I am thinking about trying to do sand blasting for a finish on some turnings. So I need info on where to buy a set up, also how to and any other information that might help.
sand blasting
Jim Canning
Re: sand blasting
A few years ago I had a task that required sandblasting (wheels for a van) so I got a quote and it was extremely high and I would have had to wait some time to get it done. I was having the Van painted so wanted to get it completed. I tried out the cheap siphon type units and got nowhere. I ended up purchasing a Harbor Freight pressurized unit and it did work - however you really need a BIG compressor to do much. I have a CH 60 gal cast iron style compressor rated at about 9 scfm at 90 psi and I had to wait more than I ran. I also used a lot of sand. I purchased the sandbox sand at one of the Borgs and spread it on a tarp in the sun until it was dry before use. As I have a gravel driveway I didn't have to contain the sand. I think I used about 400 lb to completely remove all paint and rust from the 4 rims. It is messy, impossible to use inside unless you have a Sandblast self contained unit. I did try one bag of the abrasive recommended for the unit but it cost several times as much as regular sand and didn't really do much more. The other problem I ran into was that the air caused condensation in the pressurized tank, causing me to clean it out and dry it a couple time during use. I did have normal filters on the system, now I have added a dual separator - but haven't used the blaster since the changes. Tips also wear out fairly quickly - The unit I purchased at the time was around $50 - $60 and I ordered a few spare tips with it, I think I went though 1 or 2 on that job.
Re: sand blasting
wooden leg
The sand blasting that I have done takes lots of air or you will sit a lot. Wear sturdy protection. Eye and face is really needed, the medium hurts coming back at you. You need to figure out what medium you are going to use and what you can buy close to you. Do you want to reuse the medium, then a screen is needed to reclaim. Dave
Re: sand blasting
Wade Mackey
If you are looking at smaller pieces or areas, take a look at an air eraser. It is essentially a micro-sandblaster used by the airbrush community. The one I have is a paasche and is available from Amazon for ~ $50. You will need a small air supply
Just on TV
A. Kapocius
Tim Yoder's woodturning show just had an episode about sandblasting turnings. He cheated. He borrowed a friend's enclosed booth. Also used white aluminum (prolly aluminum oxide) medium.
Al Kapocius
Re: sand blasting
Hank Knight
Ditto the eye protection advice. I did some sand blasting with a basic eye shield - goggles with air circulation vents in the sides. I found, to my dismay, that the blast medium goes EVERYWHERE, including into the vent holes in the sides of my goggles. After a very uncomfortale night, I spent the next day in my optometrist's office while he carefully removed the media particles from my eyes. Use fully sealed goggles!
Hank
Jim although I have not done this yet,
Keith Newton
I do have one of the HF units, which works, but without a booth, just count on taking a sand shower, which will penetrate every opening of your body.
I have been thinking of finding an appliance cardboard box, which I will cut a window hole in, and two arm holes, with cuffs, and a cloth bottom, which will hang loosely over a bucket. I think the cloth could act as a filter, and funnel, and the whole unit could fold up, for compact storage, and cost nothing, except an old bed sheet.
I have a pretty large shop, ~ 4000', but after about 30 years here, if care isn't taken, finding room for tools which are only used occasionally, can induce walking sideways like a crab, just to get through.
If you try this, I would like to hear how it worked out, and what you learned. K
