drill bit for ice
drill bit for ice
drill bit for ice
Simon St.Laurent - Dryden, NY
I'm making ice lanterns this year, and doing okay despite the warmer weather than usual.
I'm using a mold from Lee Valley, and you can see roughly what it looks like at:
http://livingindryden.org/2011/12/making_beauty_out_of_cold.html
There are a few issues, most of which come from using the same lantern multiple nights. The candles (even the ones without the metal or plastic cups) tend to melt into the ice. That's okay until their remains refreeze into the ice overnight, and make it hard to remove them. I think I can fix that with a bit of a silicone baking sheet underneath the candle.
The harder problem is that the drain holes the mold creates tend to plug up quickly. I'd like to drill a bigger one (3/8" ?), using the one the mold makes as a guide.
I can experiment with various bits, but figured I'd ask if someone had done this before. Google searches turn up drilling for ice fishing, which is great but a much larger scale project!
Thanks!
(And yes, I'm still doing woodworking, just not nearly at the rate I'd like.)
Re: drill bit for ice
Don Orr
I would think that any standard drill bit would work reasonably well. My reasoning is that ice carvers often use woodworking tools to produce their sculptures. Worth a try anyway.
What if
Gary Smyth
you made the candles differently? Instead of a taper candle you made disc candles like the pictured floating pool candles (Lots to choose from - check any browser) and find out if they would float on the surface of the melted ice? . You might also consider freezing the water with a plexiglas clear or color cylinder "core" inserted. When the candle burns down then simply knock the core plug out and insert another. Probably not cheap, but might work.
Re: What if
I hadn't thought about floating candles. That might be a good option, though my "10 hour" votives tend to last 6 hours at best, and the floaters (that fit the space) look like "4-5 hour" candles. Since days are getting longer though, that might not matter.
I have to think about putting a hole through the base. That's happened naturally on some of them. Usually it works out okay, but those lanterns also seem to melt away faster than the others, losing side panels fast. Maybe that's because the candle is tilted or off-center, or maybe it's just that it's been weird warm winter for this.
The other thing I'm pondering is building some small wooden stands for the candles, to get them up a little higher when there's snow and so I don't set the lantern on packed snow and block the drain hole instantly. (See - woodworking!)
Thanks!
I looked through some ice carving conversations and concluded that everyone seems to do everything differently.
That does suggest, though, that experimenting can't hurt! Today's too warm to make new candles, but hopefully I can make a new batch tomorrow and play.
Thanks!
Bill Turpin in WNC mountains
What about increasing the diameter of the mold plug that creates the drain with duct tape or silicone caulk. Duct tape is the universal problem fixer.
You're right - I've been thinking of the ice like wood, not like something I can mold before having to drill it!
I'll experiment with that too.
Thanks!
Any bit works---ice votives
Tom Dunlap
Twist and spade bits work OK but auger bit works the best.
One winter when I lived in Minneapolis I made large ice votives. It took a little experimenting but I got it down.
Round five gallon bucket
Round 2 gallon bucket filled with rocks hanging from an adjustable length cord from the ceiling
Fill 5 with water then set the 2 gallon inside. Top off the fiver. Adjust the length of the cord so that the rim of the 2 is even with the top of the five. Leave the water to freeze. Keep a note of time and temperature so you can get a rhythm.
When the ice has frozen to a desired thickness pull out the 2 gallon. To make the nicest globes you'll find that the ice will freeze thickest on the bottom then a bit thicker on the sides. The top will freeze too but not 'freeze in' the rock filled bucket. With good timing you'll have a chamber inside that is sorta round with some water in it. Pour the chilled water in your next 5 as a starter. Set the ice votive aside to freeze solid. Most of the time the votive will slide out of the bucket/mold. If not, dipping it in a bigger bucket will thaw the surface a little. I found that having the side shell about 1/3 frozen worked best.
Once you get your system you can start a factory in the garage.
The 5ers last a LONG time! They are deep enough so that the wind doesn't blow out the candle. Kind of like a hurricane chimney.
A friend took this idea and got really creative. He put die in the water. On some of the molds the die separated as it froze leaving a darker ring at the bottom and lighter colors towards the top. Then he started freezing in layers with the 5er sitting flat. That lead to tipping the bucket to make angled layers...wild stuff but way too involved for me. Artsy cooks do the same with Jello sometimes!
I would love to do the same but Austin is way too warm :(
Tom
Re: Any bit works---ice votives *LINK*
These are great suggestions - I sense much more craziness coming on next year!
I wound up with a 1/2" bullet-point bit, and it does fine. Hopefully those holes will let the water out. I also put a piece of silicone baking sheet under the candle, to keep it from melting downward.
We'll see!
A good night for lanterns
