OT: Wireless signal adapter *LINK*
Stuart Johnson
My computer is right next to the wireless router and connected with an ether net cable and gives me a reliable 5.12 mbps up and .62 down. My wife's is a couple rooms away and connects wireless. Her speed widely varies from 2 to 5 mbps up and .30 to .60 down. Would an adapter such as this work to give her a better more consistent speed? There seem to be many brands and speeds, this one is just an example.
powerline AV 500 adapter
Re: OT: Wireless signal adapter *LINK*
Dustmaker Mike
Most likely not. A lot of the signal strength may be lost in the walls of your house as well as from floor to floor. The best thing you could do is move the wireless router to a more central place in the house.
Chuck Bjorgen
Stuart -- My router is located in our basement so when I added an iPad to my arsenal, I found it hard to pick up the signal in my upstairs room and particularly on my back porch where I spend time during good weather. I added a NetGear Extender system to pick up the signal and it has worked well. I did have to find the best position for it but after about four different locations it has done well for me. NetGear had two different models of signal extenders and I chose the WN2000RPT.
Stuart Johnson
Thanks, these seem to use the house wiring to send the signal from the router to the unit. You then plug it in with a cable instead of using wireless. I've read a bunch of reviews and right now I'm trying to decide if both units are included or just one. I like sites that have a "what's in the box" link.
Bill Howatt
I think your "up" and "down" are reversed. Down is coming from the internet to you and up is from you to the internet. Down is always faster.
Before you do anything, put your wife's machine closer to the wireless router. Wireless G, a common standard in use, is 54Mbps which gives a lot of room for losses. Even the old Wireless B is 11Mbps but if packets get corrupted for any reason the throughput will indeed suffer.
Interference from other sources such as wireless telephones and even a neighbour's wireless equipment can interfere. The 2.4Ghz band is used and is shared by phones, baby monitors, garage door openers, etc. You may be able to select the default wireless channel number on the router to see if it helps.
If placing your wife's machine closer fixes the problem then changing the router location or using an extender can help although I'd pursue the different channel option first.
Bill
John McGaw
Is there any major reason for not running an Ethernet cable down to where your wife's computer resides? It is really a rather simple process in most traditionally-constructed homes, especially if you can run the wiring through unfinished attic or basement space. Some CAT-6 cable, a couple of low-voltage old-work boxes, a couple of faceplates with tombstone connectors, and a couple of hours is usually all it takes when things go well. An installer's bit is usually the only 'special' tool required.
This is an ethernet wire extender, not wireless..
Tim Greif - West of Chicago
This type of device simply extends your wired ethernet cable over the house wiring. You need one of those adapters at each location where you want to plug into the ethernet network. In your case, you need one in your computer room where the wireless router is located and one where your wife's computer is located. You connect the first with an ethernet cable to an RJ45 port on your router. You connect your wife's computer to the second one with an ethernet cable. The wireless link will not be usd in this case. It will be as fast as when she plugs her computer into an ethernet port on your router.
Forgot to mention
Bill Howatt
I had a slow speed problem that was intermittent and it was caused by the wireless adapter in the PC. I bought a new USB wireless adapter. Of course, it could also be the wireless portion of the router as well.
Bill
Lee Schierer McKean, PA
Until this past august I had a Netgear router with wireless capability. I could barely get wifi in the next room with my blackberry. We took a lightning hit that killed the router. I replaced it with a Cisco Linksys E1200 which took almost 5 minutes to install and set up. I now get good signal anywhere in the house and even outside.
Lee
Stuart Johnson
Thanks for the input. I'll probably stick with what we have or buy one at Staples or Best Buy where it can be returned if it doesn't work.
Jim DeLaney, Austintown, Ohio
A year or so ago, when my Linksys router croaked, I got an Apple Airport Extreme® base station router (not just for Apple - works with any PC) multi-channel router. A bit expensive, but way better than any other I've seen or read about. My shop is over a hundred feet, and half a dozen walls, away from the router, but I still had a fair signal (25Mbps) out there. Then I bought an Apple Airport Express repeater for the shop and now have 130+ Mbps reception out there.
Pricey, yeah, but it solved all my connectivity problems.
