Moving DC OD
retiredguy
About a year ago, I posted a message soliciting opinions about removing DC to a separate, but attached, building. I received some good suggestions.
I completed the small addition to my shop last spring and thought I should share the results with you folks.
I live in an older section of a village, so I'm very space-constrained on my lot. I heated my shop with an OD stove for several years, but it had a tendency to produce a fair amount of smoke which produced a complaint from one of my neighbors on the next block. So now I'm back to heating the shop with baseboard electric heaters.
When I removed the stove, I was left with a concrete slab. I increased the size of that slab to a square of about 5 by 6 and built my new addition on it. The building butts up against the shop but is attached to it only through the interface opening. The opening occupies one of the stud bays and is about 3 feet long.
The addition is heavily insulated and features an outside door so I can access the equipment. Installing the door was the hardest part. As you might guess, the opening for the door is far from standard. Since I didn't want to pay big $$ for a custom door, I bought an off-the-shelf metal door and retrofitted it to the opening. You don't want to know what that retrofit involved....
Once the construction was completed, I moved my Grizzly DC into the building. I left the cyclone can in the shop, though, so I can empty it easily. I had some extra space, so I moved the compressor as well.
It's really nice to have the extra space, and I really like the fact the noise of the DC unit has been decreased by 3/4.
I put an OD thermostat in the addition so I could monitor temp. I had some concerns, so I installed a 70 cfm fan in the interface opening to circulate air from the shop. Works great. The building temp is usually 7 or 8 degrees less than in the shop. When I'm using the DC, it actually is warmer in the addition than in the shop.
So far, really good. The temp is 15 outside today and its 49 in the DC building.
Just though I would share my experience.
Doug
