Sandflee
Sandflee
Sandflee
BQ in VT
Has anybody used one? All the reviews I have read fall into 2 categories: either it is the greatest thing since sliced bread or it is a piece of garbage. I also have read reviews saying that their customer service is the worst. If this tool does work as advertised, it would be a huge time saver for me. My work has lots of small pieces and edges that are very time consuming to sand by hand. I was looking at the 9" model that I would set up with the fence. I would desperately love to hear anybody's thoughts on this.
Many thanks.
Re: Sandflee
Re: Sandflee
Charles Yawn
I have had a (9") Sandflee for a few months. Overall, it does what it was advertised to do and what I expected it to do. I use it to sand off bandsaw marks on wide and thin sheets of wood to be used on the scrollsaw. The stuff that a thickness planer would eat up. Kind of low powered but that has not been a problem; just go slow. Very quite. I had a bunch of velcro-backed sandpaper already and cut my own sheets for the drum. The finer grits are not useful and super slow.
The only gripe I have is that on one end of the sandpaper wrap, the end can come loose and unwrap unless you tape it down. Design flaw, in my opinion. If you have any specific questions, ask away. Charles
Re: Sandflee
Re: Sandflee
norm knoxville
I have a Flatmaster available if you are interested. It is similar to the sandflee.
Re: Sandflee
Re: Sandflee
BQ in VT
I am interested if you are selling it. How much are you asking?
Thanks,
BQ
Re: Sandflee
Re: Sandflee
norm knoxville
BK, is there a way I can call you tomorrow? I will be able to take pictures and layout the extras etc. Norm
Re: Sandflee
Re: Sandflee
BQ in VT
Hi Norm,
before you go to too much effort, did you have a price in mind? on review of things, my budget is somewhat limited, but I would like to hear what you are asking.
Thanks,
BQ
Re: Sandflee
Re: Sandflee
norm knoxville
I'm thinking $450 plus shipping. Unit includes fences and wheels, mounted motor / switch and a couple of rolls of paper. What will you offer? Norm
Re: Sandflee
Re: Sandflee
BQ in VT
is it the 9" or 18"?
Thanks,
BQ
Re: Sandflee
Re: Sandflee
BQ in VT
Thanks for you reply. I am interested in it because I have lots of small parts and edges to sand in my work. I was thinking this could be a real time saver. Does it work at all with finer grits? If I could set up 80, 120, 220 on the drum and get decent results, I could potentially save hours. In your post you made it sound like the finer grits don't work? Also, have you had any problems with the machine or motor? Some reviews I have read have complained about the motor.
Thanks for your time,
BQ
Re: Sandflee
Re: Sandflee
BQ in VT
oops, you said Flastmaster, not a Sand-Flee, my mistake. Disregard the previous post. I guess if you cold send some other details and post a picture, that would be great. I am not sure how to price it atthis point. Thanks for for time.
BQ
Re: Sandflee
Re: Sandflee
norm knoxville
BQ www.stockroomsupply.com is the website for this tool. My email should be visible in my profile if you want to talk further.
Re: Sandflee
Re: Sandflee
Charles Yawn
The SandFlee works with all sandpaper grits - the finer grits are just much slower working with the wide sheets of wood I am sanding. I found that I get a good surface with 80 grit, then a good, final smooth surface with around 150.
No problems with the machine or motor. Actually, it is much quieter running than expected. And, if set up as instructed, it is powerful enough. I think people have problems with it bogging down when they try to sand too much in one pass.
An issue I remembered after my earlier post; one end of the drum shaft sticks out the side of the box about an inch. When on, this exposed spinning shaft could be a safety issue. I will probably rig some sort of cover for it.
Charles
