Repairing a Throat Plate Questions
Isn't tech insert in a TS called a Throat Plate? The one the Blade rises through?
I have a Rockwell Delta Contractors saw and the plate is made of some sort of pot metal and has become sway backed over the years. Its down a 1/32 to 3/64". Its not flat, so adjusting the leveling screws does not help.
I was wondering about coating it with Bondo and sanding it flat. Will Bondo adhere to pot metal? Is it tough enough too take the abuse of stuff sliding across it? How about covering the Bondo with a piece of plastic laminate? Or would I be better off buying and after market plate? Any suggestions?
