Sofa table shelf *LINK*
mdclor
I have been commissioned by LOML #2 to make a sofa table similar to the one in the link. However, in place of the steel stretcher, she would prefer a shelf. What are the preferred methods for attaching a shelf? My initial thought is to run a pair of wooden stretchers with short spindles between them. This would provide a "shelf", but would avoid the movement and strength issues associated with a solid shelf. Other thoughts or suggestions?
TIA,
Merle
FWW Sofa Table
Re: Sofa table shelf *LINK*
Jesse Cloud
Looks like a fun project Merl!
I did what you suggested, but with slats instead of spindles (just because I don't know how to turn) and it has worked fine for 6 years.
Here's an article that shows a few ways to skin the cat.
Hope you will share pics of the build and the final project!
FWW on table shelves
Re: Provide a pic? Link needs FWW memership?
mdclor
Sorry about that. I thought the article was in the public area.
Make It Easier
Forget the shelf. Structurally, it's not needed, and stylistically, I think it's out of place.
mdclor
Jesse,
Thanks for the link. I had forgotten this article. At this moment, I am leaning toward the frame and panel solution suggested in the article.
I may have used the term 'spindles' incorrectly. I thought that narrow square slats were sometimes called spindles in A&C style construction. But you are correct that I used slats. In any case, I want to avoid that look in this project for something a little more 'elegant'.
Regarding the shop shots, we will have to wait and see. :)
Thanks, again,
Merle
Re: Make It Easier *LINK*
mdclor
Mark,
I'm with you on that. I love your table and had even proposed Stickley Sofa Table 89-857 to her. Maybe I can convince her that a cleaner look is better. ;)
Stickley 89-857
Re: Make It Cherry
Re: Make It Cherry
mdclor
That is beautiful figure in the cherry, but I already have the qswo legs made.
Re: Make It Easier
Bruce, a MN Galoot
If you do go with the shelf, I'd vote for a frame and panel. But failing that, it's easy to stick in rails and lay a shelf on top of that. I've done that as an option on several night stands of essentially the same construction and style.
If You Must
Have a shelf [SWMBO rules ;) ], use an m&t stretcher between the end legs. Then you have your choice to m&t the shelf into the stretchers with a peg in the center like this
or m&t one or two long stretchers into the leg stretchers and lay your shelf on top. Were it me, for a long and narrow shelf I'd use 1 stretcher down the middle and use three screws up into the shelf. That would allow the shelf to expand and contract, yet hold it firmly in place
Re: If You Must
mdclor
Mark,
That is a really interesting approach. Due to the length, I might use 3 stretchers and only attach the shelf to the middle one.
Stretchers
One long one is enough. The other two won't add anything except the ability to rattle against the shelf if you get movement that creates a gap.
