Veritas - Innovation in Tools
compressed tank for pin gun
wooden leg
My son really doesn't want to pull hose or pack my portable air compressor around the house when doing the trim work. He saw some rug installers using a "tank" with a small hose running to the gun. What type of gas and where would I get the gauges? Thanks, Dave
Re: compressed tank for pin gun
Rick L
Rick L
Jacpac is co2 set up that can be refilled at paintball stores
Air Tank
Lots of places (just google) to buy a 5-10 air tank that'll refile to 150psi from a compressor. Good for a couple dozen shots on a brad nailer or pinner before needing to be refilled from a compressor. Come with gauges etc. Cost $50-60 depending on size.
Other solution is to buy a compressor gun (battery op'd) pump on board. Hear they have problems but mentioned it anyway.
m
Re: Air Tank
Lowe's was selling a System where your wore a bottle of CO-2 on your belt and hooked the gun to it through a short coiled air hose. The bottles were the same as or similar to the ones for paint ball guns. the cost was pennies a shot for small guns but pretty rough for framing nailers. They discontinued them so I don't know if you can still find one.
Way back in the day I used to buy nitrogen in big steel bottles (like the ones of an oxy - acetylene torch) and leave one on each job. I was a builder. We used them to staple the plywood tot eh roof and the storm siding on the houses. Worked out to fifteen cents a sheet. You can't do it anymore, they are afraid the guns will explode if the regulator fails. The tanks start with about 2200 psi, so I guess it was dangerous. Might look into using CO-2 bottles for the same thing. Just use a quality regulator. I think you would have to keep the bottle up right and the compressed gas is a liquid in the bottom of the tank.
Joseph Mulherin
You could also use a scuba tank of compressed air...about 2,000 psi worth in them
and can get refilled at a dive shop.
Re: compressed tank for pin gun *LINK*
Bill Howatt
I use a tank similar to this. I'm sure you can find one in a automotive or similar store in the US.
I just fill it to 120PSI with my air compressor. I replaced its hose with a standard air quick-release connector and made up a connector with regulator and another connector. I can drive a lot of brads with it between fills.
Bill
Air Tank
That is what I use sometimes.
Keith Newton
I could get over 120 shots with my old senco guns, but I have not checked my newer guns.
Two male quick connects back to back allow hands-free fast filling.
John E. in SC
Scuba tanks are usually filled to 3000 PSI. Probably too dangerous, heavy, and expensive to be lugging around a job site! Did have a former dive instructor that carried around an air chuck adapter for scuba tanks in his truck in case he ever had a flat, but I don't think he ever used it.
Senco PC1010 1-Horsepower
McKay
I purchased this unit for just the purposes described above. I really did not think that I would use it that much, but it is so affordable that For 120 bucks I have used to A LOT. I found this unit to be small, able, and much easier to recharge than the air tanks that you have talked about. I charge the unit and have used it to air the neighbors wheel barrow. It is light enough that I do not give myself a hernia lifting it into my truck.
Joseph Mulherin
Back in 1970 I was listening to KGO radio from San Francisco and heard of a guy that made a "car" to be used for driving across the Golden gate bridge everyday to and from work. It had a jackhammer for a motor, powered by 2 scuba tanks; and the tanks were recharged with a compressor which was attached to the drive line; and the electric startup motor was recharged by a generator attached the same way.
He would start off with the electric drive, then switch to the air drive....and it did work.....!!
Just buy a cheap compressor *LINK*
Tim Greif - West of Chicago
I have a really inexpensive 2-gallon compressor for routine air nailer jobs. This little POS runs brad and pin nailers as well as staplers just fine. The one in the link is private labeled by many companies. Mine is Coleman but the same chinese-made compressor is available everywhere for around $50.
mini air compressor at Sears
Brian A
I think the Tata car company in India is working on making a compressed air powered car. Would be cool!
Google Tata Compressed air car for more info.
Brian A
Milwaukee
Re: Just buy a cheap compressor
Carol Reed
Surprised no one mentioned this: http://www.harborfreight.com/catalogsearch/result?q=air+tank
