Successful complex assembly tips
Bill Tindall
Assembly of complex parts with multiple joints
There are some tips that apply to any complex glue up, as illustrated by the assembly of this back panel for a chest of drawers. It involves assembling 14 mortise and tenon joints. In this example the frame is ½” poplar and the raised panels are 3/8” poplar. The panels are the remains of resawing thicker lumber for the drawer sides. I hate wasting wood and try to use whatever I can somewhere.
I like to use a paneled back for a fine piece of furniture. One can’t tell where or how it will be used in future generations and a finished back could make the piece more useful in the future.
Tip 1 Don’t make the joints so tight that they are difficult to assemble. If they don’t go together easily by hand before applying glue they will be a problem during assembly when the wet glue swells the parts.
Tip 2 Dry fit the assembly . This step achieves several important objectives. 1. A test that everything fits and aligns 2. A rehearsal for the order of the assembly steps. This particular assembly only goes together in one order. 3. Clamps and pads are selected and adjusted.
Tip 3 Number each joint so there is no mistake what part goes where. Mark alignment points for each joint. I have darkened some of these marks so they would show in the picture, for example in the center cross pieces.
Tip 4 Use liquid hide glue. It has a long assembly time and it is “greasy” such that the joints act like they are lubricated during assembly.
Tip 5 If the final assembly needs to be some predictable shape assemble the whole structure at one time. After assembly the glue is fluid enough that the shape can be adjusted to perfection by altering clamp positions.
Tip 6 Prepare the glue in some handy container. I use disposable cups set in a block of wood so that the cup doesn’t move around. I like the small thin “lab” spatula for spreading glue. I pick up a dab of glue on its end and swish it around on both surfaces of the mating parts. Glue must wet the wood to bond. The best insurance for a good bond is to spread a thin layer of glue on both mating surfaces, especially in a mortise and tenon joint.
Tip 7 Don’t spread glue on a part too far ahead of assembling the joint. With hide glue the joint stays flexible for many minutes after assembly. But if the air is dry and warm the glue on an unassembled joint will form a dry skin that interferes with bonding. During dry fitting make a mental note of the optimum way to combine glue spreading and assembly. In the example at hand I spread glue on the mortise and tenons for the center divider and assembled it, added the panels, then applied glue and assembled each end, and finally the sides.
These tips will aid rapid, and reliable, assembly necessary for a complex part like this frame and panel assembly.
Re: Successful complex assembly tips
"Complex assembly" is a relative term.
Keith Newton
My current project is up to 200 parts, each with 4 glue points, which are too close to dry assemble, and still be able to get apart without the lubrication of the glue, so I'm having to take extreme care in QC, to make sure that I don't get something going in, which can't get there, nor so loose as to hurt the strength.
We'll be over 300 parts before we get through, so think 1200 glue points. Ben, my assistant and I are having fun with this one. We've been having bouts of breaking out in spontaneous laughter as it goes along.
Re:  "Complex assembly" is a relative term.
Thomas Norton
It would be interesting to see this "Project"!
