old jointer
old jointer
old jointer
Eric in Los Gatos
I have been lusting after an 8 in jointer for a couple of years and waiting for the right deal to come along. I found and old Rockwell-Delta jointer that looks and oldie but a goodie. I took a look at it this morning and, aside from everything being a little gummed up it looks pretty good. I checked the tables for coplanarity. (Ooh look. I made a new word.) and the outfeed table is out by about .005 in. in one diagonal. Everything else looks perfect. Turned it on and it runs smooooooth. Fence seems OK but engaging the lock throws the adjust off so that will be a crap shoot. Might be helped by cleaning. Knives are sharp.
Overall looks like a good piece of old iron. My question to you is: Should I be checking anything else?
Thanks,
Eric in Los Gatos
Re: old jointer
Re: old jointer
Check the flatness of the fence.
Good luck
Tom
Re: old jointer
Re: old jointer
Bob Hackett
Check,clean and adjust the gibs (if it has any) and the adjustment screw and nut on the infeed table. I`d also check the coplanarity ( :) ) on the pullies as well as the keys and locks. If it has an old motor try blowing it out real well and oiling the bearings if you can get to them and they`re not sealed ball bearings.
I`d also check the end play on the cutter head, and be sure all the screws that hold the knives are tight and locked down well.
I`d also look for an owner`s manual for it online. You`d be surprised what`s still available and can be printed up as well as the wealth of information you`ll find in one.
Re: old jointer
Re: old jointer *LINK*
If you buy it, you want to get familiar with the Old Woodworking Machine forum, see linky below. This group can give you endless useful advice, access to literature, often quite helpful suggestions on good parts sources, etc. Just be sure to read the rules; while there aren't many, they're slightly different from here (every forum has its own), and strongly administered.
Oh, and the humor is...well...vigorous. If you post a picture to ask, "What's this?" about a part, make darned sure there's nothing else in the background, or you'll get some odd replies.
http://www.owwm.org
