water percentage
water percentage
water percentage
wooden leg
I have a meter that tells me what the moisture % is in wood, its one that you hold on the wood. Is the one with pins better. I'm having to use very dry wood for a current project and was wondering if the the pins might be better. Thanks, Dave
Re: water percentage
Re: water percentage *LINK*
Keith Newton
Dave, Here is a link to another forum, where i think you can get good advice on this subject. I think you can find other threads there, if this doesn't answer your question.
I have both types. I'm sure you have the charts to compensate for wood species, but I think the pinless are suppose to read deeper than the pin type, unless you get the professional ones with the long prongs and slide hammer / big artillery.
http://www.woodweb.com/knowledge_base/Moisture_Met
Bill Tindall
None of the meters is accurate at low moisture levels. For low level determination use the reference gravimetric method.
