Help! My last Japanese maple is struggling!
Ken Bellock (Houston, TX)
My last (of 9) Japanese maples is struggling, and I really want to save her! She is less than a year old and about 18 inches tall, and all the leaves are turning brown from the tip in, and falling off like the last 8 just before they died. Some of the others had their roots eaten out by ants, or just dried out and died. I have tried lots of water, little water, hot, cold, humid and dry.... This one is alive because all of a sudden it just burst and grew and was happy for a short time, but I dont know why, five others died with the same treatment.
Please help! What can I do to save this last tree?
Pics to follow...
Re: Help! My last Japanese maple is struggling!
Bill Turpin in WNC mountains
Japanese maples are deciduous, they are supposed to loose their leaves.
The others died during the summer the same way, and they where dead, not dormant.... This is TX, just trying to keep this guy alive till I move back up north... Pics coming as soon as my PC cooperates...
Blue
Try moving it, use rainwater if possible, some new miracle-gro garden soil for trees. Good luck!
I feel your pain. I love Japanese maples. I have about fifty. Various cultivars. Been collecting them for about 25 years. My son got the bug too ad he just got a new one the other day.
I think you are too far south. They are a more northern tree. Moving further north might be the answer.
I am not a plant pathologist but I would suggest you check out phytophthora root rot. I have lost several to that. There are chemicals you can get tot treat the soil for it
could be a fungus among us
Dick Coers
My red oak has done similar things for the last two wet springs. The leaves settle out when the summer gets dry, but the leaves curl under and get a more black color on the edge. There are fungus sprays available. I haven't had the oak sprayed, it's over 30 ft tall. Planted it when my son was born, June 28, 1980.
Get it in the ground...
Tom Dunlap
...or a better pot.
More soil volume with a mix that can hold water but not stay damp. I'm going to bet that the tree got toasted sitting in front of the window. Taht isn't a good place for J Maples.
J Maples don't do well south of about Waco. Too much heat and dry...even in muggy Houston. Any J Maples in Austin are on borrowed time. They will sooner or later get burnt up. We're going to have another summer like last, maybe two summers in store.
Tell me about the soil.
Re: Get it in the ground...
Stuart Johnson
I agree with Tom. When we lived in Katy, TX we planted a J. Maple about the size of yours. It was properly watered, in full sun and didn't do squat for three years. When we moved to Virginia I dug it up, stuck it in a pot and tossed it in the back of the moving van. It sat in the back with the door closed for about a week. When I opened the truck it was full of leaves and once planted took off so well I didn't even think about digging it up again for our next move. We're in Red Oak, Texas now about 25 miles south of Dallas. The nurseries are always full of them this time of the year but it's rare to see one. I think the heat and full sun is what does them in. You might be fighting a lost cause unless you can plant it or at least put it in a much larger pot where it gets a lot of shade.
The soil is miracle grow moisture control potting mix. I have tried several locations inside and out of the house. This is a south facing window and only has a short time with full sun. It goes through mini bursts of happiness where I think everything is going to be ok, then a coulple days later with the same location and treatment it starts drooping and the leaves start turning.
Looks like leaf scorch
http://extension.missouri.edu/p/G6881
I had that on my maples in my house back in Marietta.
Soil and roots
Tom Dunlap
If the soil doesn't have enough air in it the roots will die. Potted plants cannot take the dry/wet cycles very easily. J Maples are NOT a full sun tree. Having it sit on the windowsill can cause wild temp cycles.
A simple and effective way to test soil moisture in a pot is to use a pencil with an eraser. Poke it into the soil at varying diameters and depths. If soil particles stick to the eraser the soil is wet. If it comes up muddy...too wet. Don't water until the soil is dry. More potted plants are killed from over-watering than underwatering.
The leaves may look like 'leaf scorch' but I doubt that is the problem. Leaf scorch needs different conditions than one would find inside a house.
I'll bet dollars to donuts that if the JM was unpotted the roots would be rotted. There would be very few hair roots that take in nutrients and water from the soil.
Too often people think that adding fertilizer to plant that is struggling is the right thing to do. That is the furthest thing from proper. Fertilzer is NOT food..it is nutrients...a HUGE difference. Plants produce their food using photosynthesis using nutrients from the soil. Animals need food to grow since we don't make it inside like plants.
Adding fert can give the disease organisms a super boost leading to further decline.
Like 'A Field of Dreams'...build it [roots] and they will come [grow].
Footnote...I'm an arborist...Tree surgeons still make housecalls!
Clementine
Maples require a neutral to slightly acidic soil, but definitely not alkaline. Alkaline soils block the uptake of iron for maples, so they look good for a while, but never thrive. You could put it in a large pot, but that really is not practical. Drive around your neighborhood and see if maples are growing there. If not, that is a good indication of the soil type that is not conducive for them. You can always check with your county horticulturalist or a reputable garden center (NOT Wal-Mart).
