Santa brought a Shelix
Tony - Memphis
Santa brought me a Shelix cutter head for my DeWalt 735. I got it installed yesterday. Has anybody else done this? The install went pertty well. The first surprise was that when I removed the cover over on the height adjustment side, the 23mm nut that holds the drive pulley on the cutter head was laying inside the cover! Glad that didn't cause a problem. The install directions were pretty good. The only question I had was how far to press the new cutter head in. I got it past the clip slot a bit and stopped. The pulley seemed like it was aligned pretty good. Something to note if you perform this swap. Nice to have the exploded parts diagram handy too in case you forget where what washer went where and in what order. Now, I didn't want the nut to come off again, and the cutter head lock doesn't work with the new model, so I used a piece of soft wood slightly wedged in between the head and case to hold it while I tightened it. Didn't get to crazy, just good and snug. Oh, and I had a hard time getting the pulley off. I used a wheel puller that was way too big, but I managed to get it to work. A 23mm socket, 6mm socket, and snap ring pliers are needed for this swap. The socket head bolts holding the transmission in are metric, but I can't recall the size 4 or 5mm?
The planer sounds very different that before. It also draws about 1 amp more than before when cutting ~1/32 off of a 5" wide piece of soft wood. The cut quality is ok. I have a ridge that I am trying to get rid of. I sent them an email asking about it. I tried removing a couple of the inserts and cleaning and re-installing. That didn't work so far. I noticed that the screw whole counstersink had a slight burr around it. I wondered if that was pushing an insert up a little. I tried touching it with a small diamond stone just to remove the burr. Still didn't fix it. I'm pretty sure I had the guilty inserts identified, but I am going to spend some more time messing with it. I ran a piece of tiger maple through and, other than the line, it did a nice job. Not a glass smooth surface like the knives, but no tear out. I hit it with 240 grit and then 320 and it is a very nice surface.
So, overall, I'll be satisfied when I can get rid of the line. It does frustrate me that given the high cost, it deosn't work perfectly right away. I hate spending that kind of dough and having to tweak something. Well, Santa spent that kind of money, but still! And for some reason, I am getting snipe again. I had messed with the planer a while back and gotten rid of it (in/out feed table adjustment). I wonder if the different diameter cutter head has nything to do with it?
Tony
