Steam bending problem
Royce Meritt
I made my first attempt at steam bending a few days ago but had a minor "issue".
First of all, my set-up:
I built a steam box of 3/4" plywood. Placed a metal gas can on an electric hot plate. Attached a piece of 3/4" ID vinyl tubing to the gas can and ran that to my steam box.
Now the "issue"...
Once the water started boiling it seemed to produce a good amount of steam but from time to time seemed like the steam stopped going into the steam box. The vinyl tubing became VERY warm and seemed to get a lot of condensation on the inside of the tubing. I think I was losing too much heat through the vinyl tubing and the steam was condensing back into a liquid before it reached the steam box.
Does that seem like a reasonable explaination or is there some other problem with my set up? Would insulating my vinyl tubing or using a different type of tubing help? ANy other thoughts?
Thanks.
Re: Steam bending problem
Re: Steam bending problem *LINK*
Bruce, a MN Galoot
without seeing your setup, it's hard to say. BUT, I'd guess that the 3/4" tube is a bit small. I use a radiator hose feeding off the top of a tea kettle parked on a camp stove. You also need a vent in the steam box. The extra steam and condensation need a place to go.
If you've not done steaming before, Lee Valley has a wonderful pamphlet you can download:
Lee Valley Steam Bending Booklet
Lee Schierer McKean, PA
Yes you need a vent on the far end away from the steam inlet and you need to slope your steam box toward the vent which should also function as a drain. It will take 30 minutes or more of steaming to soften the wood so be sure you have enough water in your boiler.
Lee
Ralph Lipeles
You need to make sure that there is no resistance to the steam flow. I built a "steam box" from a piece of 4" tubing. My first attempt had a tea kettle spout just sticking into a hole in the middle of the 4' length of tubing and rags loosely placed in the ends of the 4" tubing. It performed very poorly. I then removed most of the rags and the steam flow looked great and worked great.
John Veerkamp
And your steam box should be higher than the steam source with no dips that could trap steam.
Jim Hoeller
I have used a Wagner wall paper remover (steam) with good results. It includes an insulated hose. Look for one on Ebay or Craigslist. It has also been repackaged as a source of heat for steam bending at a higher price. The other item you need is a thermometer (gauge type) so you can make sure the temperature in the box is betweeb 190 and 210 degrees farenheit for one hour per inch. The idea is to heat the wood to the point that the lignin in the wood becomes plastic and will bend without breaking.
I agree with Bruce, except,
Keith Newton
Get the lee valley booklet, and read it, then follow it as closely as possible. However, the tube diameter is not important, but the material is. Vinyl is not a good choice. I have used 1/4" copper tubing connected to a canning pressure cooker successfully for a long time, but I do have it insulated well.
Insulating the chamber is also important, especially if you are doing it outside in winter. It is the heat that makes it work, not the moisture in the steam. If you are loosing half your heat through the walls of your chamber, due to cold outside, and good conductor material for the chamber, the hour per inch rule is worthless.
I've been thinking about getting one of those meat probes that send a signal to the outside, then drilling a hole from the end into the middle of the thickness, so I can know that the interior has reached 200º.
Also, if it is cold outside, I will have a sheet of aluminum foil laid out, so as I extract the steamed part, I can instantly lay it on the foil, which I will wrap, to trap the heat, and prevent evaporation, which should increase the time for getting the work bent around the form. If the temperature in the middle never makes it over 200º, or the surface temp drops before the bend, the chances of success are slim.
Don't overlook the end compression straps.
Re: Steam bending problem-THANKS!
Royce Meritt
Thanks for the replies everyone. You've given me some good suggestions.
