Retractable Electrical Drop Cord
George Colonel's Workshop-Havertown PA
Good Afternoon Friends,
My #1 son bought me one of these a dozen years ago for shop use. We hung it and I used it probably more than any other single/duplex connection in the shop. It provides me with 30 feet of cord if I should ever need that much. Lately I noticed that the connections are becoming loose, and sometimes the plug tabs fall out of the receptical's slots. I hate to replace the device, as it is perfect for my shop size. Any suggestions would be appreciated. I don't want to re-wire a new end, and then pull on it all the time.
George
Re: Retractable Electrical Drop Cord
Howard Norman
Why not put a new outlet on the cord that has the clamp to grab the cable?
I know that I have seen that kind at Ace if not at one of the borgs. The ones that I have purchased over the years are very robust.
Dale Lenz
Re: Retractable Electrical Drop Cord *LINK*
Dale Lenz
Do you plug your tool to extension cord the way show in the link?
Plug
Lee Schierer McKean, PA
Do a google search for Retractable Electrical Drop cords and you will find several rated for 10 amps with 16/3 wire. Prices run between $27 and $50.
McMaster Carr carries heavier duty cord reels but the prices are commensurate with the current rating.
Lee
McMaster Cord Reels
wooden leg
My first reel was from HF and it bound because it was enclosed. The second one came from my local NAPA store, nice price and is 12 ga. Dave
Replace the plug
Dustmaker Mike
As someone else said if every thing else is working correctly I would just replace the plug end wit a good strain relief on it. Happy New Year
Possible solution, and question *LINK*
You used to be able to get split rubber balls, held together with screws, that would clamp around the cord. They were used to stop the cord, as it reeled into the canister, before the female plug end hit, so as not to strain that connection. You can see an example several of the drawings in the linky below.
If they're still available (check with an auto parts house or industrial supply house - if you turn up a blank, ask the auto parts folks where people who run service stations get parts for their air hoses, as these bumpers are commonly used on air hose reels), seems like nothing would prevent you from putting another one right next to the female plug, so that you pulled on that rather than on the plug itself. That should provide good protection for the plug. In fact, when I get around to installing the reel I've got, I think I'll do just that.
One question, wandering off your original topic, but still kind of related, and asked both of you, George, and of the rest of the crowd around the cracker barrel here: a tightly coiled cord with current running through it will heat up, as the current creates a magnetic field (just as the coil on a transformer will heat up some). Have you ever had problems with this on a cord reel? I've wondered whether it would be good practice to pull all the cord out every time it's used.
http://www.mcmaster.com/#electric-cord-reels/=fn00sg
Re: Possible solution, Hose Reel Bumpers  *LINK*
http://www.mcmaster.com/#hose-reel-bumper-stops/=fn0bcu
Joe Bradshaw
Re: Possible solution, and question
Joe Bradshaw
Slightly off topic, but when I was a navy diver, we were doing a long term test of coatings for welding rods used under water. We would routinely wrap one of the welding leads around one of the test plates so that it would magnetize the test plate. This resulted in a lot of expletives deleted when the diver returned to the surface.
Jason Roehl in Lafayette, IN
My experience with that approach.
I used to tie two cords together like that, but I found that it was really hard on the male plugs, particularly the ground plug. Picture what happens when you try to pull the two cords apart when they're tied together like that. Now, if I want to keep two cords together, I hold about 18" of the ends of the two cords parallel, tie them in a half-hitch, THEN plug them together. It makes for a larger wad of cord that catches on things, but it doesn't trash the plugs.
With the cost of copper (and extension cords) these days, I'd put a new female end on it. I just saw a 12-ga, 50' flexible-jacket extension cord at the blue borg for $70. I used to buy similar cords for $20.
Jason
Robby Wright in San Marcos, CA
Bill - What you are referring to is inductive heating, caused by the impedence as a result of the inductance of the coiled wire. All those fancy terms mean that when you coil a wire, it creates an inductor, which has impedence, similar to resistance in a light bulb filament and causes heat when you apply an alternating current to it. However, the amount of current drawn in a typical shop extension cord is not enough to cause a significant amount of heat. This can be a problem with large electrical feeds, such as those used for light shows and such. To avoid this, the lighting technicians alternate the direction of the coils so the inductance is cancelled.
To George - I have a 14/3 retractable extension cord that I got from Lee Valley. The triple outlet on the end of it was a waste of time - plugs kept falling out of it. So I cut it off and replaced it with a good female cord cap such as with strain relief. Problem solved. Remember that there should be a strain relief device, the aforementioned rubber stop, to keep the pull off of the cord cap. It has been this way for several years now without problems.
