Buliding a "weight truck" ideas sought
Need to build a weight truck for the stage weights.
I have the casters (5" heavy duty). The weights weigh about 15-20 lbs each and are slabs of iron with notches to fit in the carrying arbors. We have quite a few hundred lbs. They are about 15" long x 5" wide x 1" thick.
Thought #1 - 2 x 10s or 2 x 8s flat with suitable bracing tying the two boards together. Lag the casters into the bottom boards. Have two 2 x 12s on edge to keep the weights from sliding off front and back.
Thought #2 - 2 x 4s on edge glued together as the bottom boards. Have 2 x 12s as the end boards.
My concern is breaking the bottom boards if I use the 2 x 10s flat. If I make the weight truck long enough (say 20" between the end boards) - we are talking about maybe 80 lbs per layer. By the time you get up to six layers we are talking about 480 lbs. Do ya'll think a 30" piece of 2 x 10 would break under that load?
