THE WOODRAT IS BACK!
How to center screw holes for small hinges?
DouginDenver
I am ready to drill the holes for the hinge screws on a small jewlery box, so I thought I'd check in for any tips. The smallest brad point bit I've seen is 1/8" - way too big here. I usually use an awl to make a starter hole to guide the bit, but sometimes wood grain or bad aim can make those off center a bit. What's the best way to get very small screws centered in the hinge hole?
Re: How to center screw holes for small hinges?
Carol Reed
All that is needed is a mark - dimple - perfectly centered. Use transfer punches. One of the truly useful items from Harbor Freight. ~$10 Worth lots more.
gary camp Bend, Oregon
Vix bits maybe you friend here, Self centering, and as small as 5/64"
glc
Re: 2nd the Tranfer punch, or try this *LINK*
Bob Entwisle in NJ
Just bought a set for work a couple weeks ago.
If you're in a hurry, take a common nail that is the same or slightly larger diameter than the hinge hole, chop off the head, chuck it in the drill press and if needed use a file with the drill press turning to file it to the exact diameter of the hinge hole, then take a hacksaw blade and with the nail spinning, start to cut the nail, when you get part way through stop, snap off the waste and there you have a quick poor mans transfer punch.
Hope that made sense.
Vix bits are nice too, but a 10 dollar set of transfer punches will cover a lot more ground.
Bob in NJ
http://www.harborfreight.com/catalogsearch/result?keyword=transfer+punch
del schisler
Are these #2 x 5/8" screw's if so i use a philips screw driver# 1 and just punch a dimple in the hinge hole it center's itself than drill with a 1/8" drill bit . I have made 500 or so box's and use a 3/4"x2" hinge and #2 screw's. That is my item's i use. Some time's i have to cut the screw end off. Now these screw's will not take much tighten they will twist off. It makes a different which wood is used. I have been doing these for yrs so i kind of know which wood is hard and need's the screw's to be cut off. If one twist's off you can do a couple thing's drill in the same hole the bit will go off to one side buy a screw can be put in the hole with out much trouble. Or move the hinge over like one screw size and redrill ? If you are buying these from a box store you are paying to much. Of course if you are making only a couple i guess you are stuck with that price. I buy the screw's by the 1K and hinges 100 at a time making them 18 cent's each not bad. good luck with box
JMOHNIKE
In the past I have used a spot of hot glue to hold my hinge in place, I will then use a countersink to establish the center, and then predrill, if the screws are brass I will first set (tap) the hole with a steel screw of the same size, then remove and replace with the brass screw. Don't forget to remove the hinge and remove the spot of glue prior to useing the brass screw.
If small use #1 phillips screw driver or #2
