THE WOODRAT IS BACK!
Bed Rail Attachment
Bed Rail Attachment
Bed Rail Attachment
Tomm
I am curious about what others prefer to use to attach bed rails to the head and foot board when making beds. Using bed bolts seems like a lot more work than using either of the two types of metal attachments that are sold in the woodworking catalogs. Is any one method of attachment sturdier than another?
Re: Bed Rail Attachment
Only one sturdy way
Bill Tindall
Want a bed that is solid for ever? Then use bed bolts. I have made at least 6 beds and bed bolted all of them. None of them is anything other than totally rigid after 3 to 30 years, and that includes a "loft bed" with 5' posts.
The bed bolt draws the tenon into the mortise and the tenon shoulders lock onto the bed post and prevent any racking. If it ever gets loose it can be tightened a bit. Either bed bolts or a bolt through an angle iron piece does the job of drawing the mortise and tenon together.
paul in AZ
I used metal hook hardware on my own bed because it was easier to do. While they work reasonably well bed bolts are a far better solution. Next time.
I agree with Bill And Paul. Bed bolts are definitely better. I made a bed and did not want to bolt through the posts, so I put the bolts in the rails and large barrel bolts in the legs. I even made a recess in one of the rails to hold a wrench. (magnets) The bed is rock solid. Family members tell me their beds made with other methods are all loose.
Gary Smyth
You don’t need bed bolts; you can use the hooked bed rail fasteners which are perfectly serviceable -- unless the user repeatedly lunges back and forth from the foot of the bed to the head. Oh wait. Never mind.
Jesse Cloud
Slightly contrarian answer here... I have used bed bolts and agree that they
are extremely solid and its hard to imagine how they could ever fail. However,
SWMBO is extremely fond of moving the furniture around. Ever time she does
that I had to crawl under the bed amongst all the dust bunnies and fiddle with the
bolts, then reverse the process at the destination room down the hall.
So I tried the mortised hook hardware. It has worked flawlessly for 15 years. I am close to 300 lbs and the missus is appropriately sturdy - we are also pretty darn active. No problems with the bed.
Also the bed bolts will need some sort of cover to hide the holes and hardware,
which can interfere with a modern, clean design.
So, both work and have advantages and disadvantages.
