OT--Computer Monitors
Ken Oakley-Sunny St. Cloud, FL
What is the difference between LCD and LED monitors? Advantages and disadvantages?
Re: OT--Computer Monitors
Dave Paine
LCD (Liquid Crystal Display) has pixels which are clear when off and change colour when on. The pixels do not produce much light, so the display needs some type of back-lighting. Originally this was via Compact Fluorescent Lamps with a white mask to diffuse the light. You may now find units which use LED's as the back-light technology. LED's consume far less power than the CFL.
LED (Light Emitting Diodes) has pixels which are dark when off, and emit colour when on. They require no back-lighting.
Both LCD and LED can have "dead" pixels. Sometimes out of the box, sometimes over time.
Some people prefer LCD picture, some prefer LED. I think you can find examples where you would prefer LCD from one manufacturer, and LED from another.
If you were into games, then you would want the fastest response to get the smoothest action. This may be plasma display - which uses even more power than LCD and CFL back-lighting.
I have had two digital display's which failed after several years. I presume in both cases it was an electronic component since I was not able to get anything to display. I got my money's worth out of both.
My wife's laptop has LCD with CFL back-light and the back-light has gone. Can still see the screen, but no brightness changes.
If I were looking for a new monitor, I would look for LCD with LED back-light for the reduced power consumption. Also some weight reduction.
del schisler
ken go to this link and read it will tell you all about both. http://www.cnet.com.au/led-vs-lcd-which-is-better-339295938.htm
Thanks Guy
Probably buy based on price
