Puzzling over dimensions on a plan? *LINK*
Stephen Kirk
I like this table I found on Fine Woodworking's Site (link below). Now, I don't need much help determining tenon sizes and placements. However, looking at this I can't determine what thickness the legs are at the top. One of the pictures shows the craftsman holding all four, and I figure unless his hands are huge the legs are probably 1 1/4" to 1 1/2". The taper looks like it goes down to maybe 5/8" or 3/4". Any thoughts on what sizes would work and look well on this?
Is this the kind of thing where everyone (except me) already knows what dimensions were commonly used on projects like this? What's funny is that I recall a debate on cut lists over on Popular Woodworking's site and I couldn't help but think that one of those would come in handy here. I like to use a plan as my starting point and then modify them, but having a good starting point is helpful.
I'd like to start with this and then make it a bit taller, maybe add another shelf. I need a place to put a coffee maker in the kitchen and hold assorted coffee things while also providing a bit of extra storage.
Arts & Crafts Side Table
Re: Puzzling over dimensions on a plan? *LINK*
Moses Yoder
Moses Yoder
This is an article that appears to discuss joinery and assembly methods without giving dimensions for the table. It assumes the craftsman has the ability to design it in such a way that it looks pleasing. The only way to design furniture on paper to make sure it looks good before building it is to draw a scale model. For instance, if you make it taller, the legs might need to be thicker in order to look right. There is no magic formula for designing stuff. Some people are tone deaf, and others can sing. I have no doubt you can design a perfectly functional table, one that will hold a sheet of paper without collapsing.
Yonak
Stephen, trying to scale from a detail on the joinery details inset page (if it's, indeed, drawn to scale), it looks like the top of the legs are 1 1/4" but, considering Moses's suggestion on upscaling components for a larger piece, perhaps, say, 1 3/8" might make it look more balanced, however my tastes tend to a beefier look.
I see those legs as being about 1 1/2" square at the top and tapering to about 7/8".
There are several things that I like when it comes to tapered legs. Rather than taper all four sides I like to taper the inner two sides only. Visually I like to taper them about fifty percent of the top dimension, but my "engineering brain" kicks in and wants me to leave them fatter so they won't be spindly. A solution to that is to double taper them. By that, I mean to apply a long taper from about a half inch below the rails to the bottom and then apply a second steeper taper to the bottom three or four inches. This leaves a little beef in the legs and also allows them to have slender "Feet". I also apply a bevel to the end of the legs to allow them to stand on a small Toe.
The legs on the table in the site you posted appear to have a chamfer on them and that's another way to make them appear lighter.
Whatever you do, consider how all these angles and chamfers will affect how you install the shelf.
Jim DeLaney, Austintown, Ohio
From the photos in the article - particularly the photo of the hand holding the legs, with the ends and mortises showing - it appears the legs are about 1½" square. This assumes that the mortises are ¼" wide, since the total width of the leg is about six times the mortise's width.
Were I building the table, I'd only taper the legs on the two 'show' faces, leaving the two inner sides untapered. Start the taper just below the aprons, and taper by one-third (leaving the bottom of the legs two-thirds the thickness of the top, untapered portion.
That's my tak on it. YMMV...
