Band saw help
dick hines
A friend is looking ofr a rip fence for a Delta 28-195 band saw. They don't make them any more. Any ideas where he could get one?
I posted on the turning page. Between the two maybe I can give some help.
Band saw help
dick hines
I just saw a profile picture of the 10"
Gary Smyth
Part number is 1349114. I can't find a picture of the fence. I thought that the 14" bandsaw table was the same as the 10". I was wrong. Still, the 14" has two different sized bar sets (long and short) that get attached by tapped holes to the table and then the fence is attached to the bars. I don't know the size of the 10" table but perhaps the 14" bars can be made to fit. The bars and the fence are heavy and I found them unwieldy. I never liked the Delta fence and the bars extended outward so that you would almost puncture your stomach if you turned toward the saw funny. Long ago I cut some Baltic Birch triangles and built a slightly taller wood and laminate perpendicular fence than the Delta metal one and clamped it down with adjustable wood clamps. Much easier and with shimming , more accurate.
Re: I just saw a profile picture of the 10"
Jesse Cloud
+1 on Gary's suggestion and if you do a lot of resawing, you might make a few
of different heights.
I hold mine down with switchable magnets, makes it easy on, easy off.
Re: Band saw help
del schisler
try tool king It showed they had it ?? good luck
