Craftsman insprired board
Dave Paine
My colleague asked if I would make a cutting board for her father. No design details, although I sent her some links to boards made by artisans. The only feedback was a positive reaction to "Craftsman" style.
The other input to the design is that her father is a 'tree hugger' (her words), so preferred domestic renewable woods.
I like to mix domestic and exotic. I love the colours in some exotics. I also love grain patterns in any wood.
So this was my solution.
I had a 1.5in x 6in hard maple board. I cut into strips. I then found the 'side grain' had some curl showing, so decided to make this the exposed surface.
I added inlay's of bloodwood (top to bottom) and purpleheart (side) including purpleheart squares between the strips. The ends are also hard maple, but a different board, so the grain patterns do not match. I wanted the 'bread board' end effect.
This is meant to be the cutting side. The side edges are beveled to accent the craftsman style.
I wanted a side for display, and not intended to be cut and to showcase domestic woods. I had an assembly of two sequential 1/4in panels cuts from a piece of curly maple, my first attempt as popping the grain. I ended up preferring just oil over tinting. This was the left over piece. I cut two 1/4in strips of curly black walnut to fill out the top to bottom side. I then cut a piece of cherry into two sequential 1/4in strips to fill out the left and right edges.
I added some 3/4 by 3/4 feet of black walnut to give the appearance of pinned tennons. The bottom side was also bevelled.
I love the grain patterns in the curly maple and curly walnut.
I like to add inlays to the edges, to try and hide the fact this is two distinct layers. I also prefer to minimize exposed end grain.
The long edges are inlayed with lacewood. The ends are inlayed with Agate Orange. Selections based on the strips of wood on-hand to minimize waste.
The only finish so far is clear 'Butcher Block Oil' by General Finish. This is clear in the bottle, but adds a hue when applied to the wood.
Posting this before I present to my colleague. I emailed some earlier pictures, but the design evolved, as is usual for my projects.
