Re: Engineered wood flooring: glued vs stapled
paul in AZ
I put down an engineered wood floor in my bedroom just 2 weeks ago. This was glued to concrete slab rather than floated. Obviously couldn't be nailed. Nailing to plywood would be easiest.
With care the old baseboards came off intact and were repainted without having to add any tacky quarter round. New baseboard is not all that expensive.
To me the biggest difference is in the feel and sound of the floor. A floated floor rides on closed cell foam so no matter how solid the engineered material it will not walk with the firmness or sound of a wood plank floor.
That said I did put down a floating cork floor in my previous house up north. Cork's resilient and soundless surface lent itself well to that.
Assuming the surface finish is halfway decent it could be many years before longevity will be a factor. If you are concerned you could wash on a couple of light coats of water based poly with a sheepskin mop. I did that on the cork floor to seal the cracks to snow and mud traffic [don't get either of those here] more than anything else.
