We value your privacy.
I'm looking for an electric branding iron to emboss a very simple logo on projects. Everything I find on the web is $150-$200; way too much for the small number of projects I want to "brand."
Anyone have any suggestions for a supplier or an alternative way to do this?
If you have a propane torch, the non-electric ones are cheaper. I've never used one, but I regularly heat the soldering copper* I use for sheet metal soldering with a propane torch. Takes a little while, but works fine, and you wouldn't need the tighter temperature range that soldering requires; just get it hot enough to burn the wood. Finding a piece of sheet metal or a small stack of firebrick that you can use to make an "oven" will speed the heating process.
*I understand from Bruce Haugen (MN Galoot) that his dad called these soldering "irons." I learned "copper" during my brief stint as a sheet metal worker, and it is more nearly correct, since the operating part is copper; see picture below. If you have hand metalworking skills (hacksawing, filing) and can find one of these cheap, you probably could whittle your own branding iron (copper). I don't know if you folks down south have garage sales in the winter; up here, except for estate sales, people tend to stop by Christmas and then lay off until later into the New Year; but I do find them from time to time at garage sales, usually cheap.
I think Roeckler still does it, or you can take wood discs to your local trophy shop. They can laser engrave wood discs, that can then be inlaid into a forester bit hole in your work.
