OT bathtub to step-in
wooden leg
My wife is getting to the point that normal bath tubs are getting to hard to get in and out of, we are thinking about putting in a step-in tub. Has anyone done this, either themselves or paid? Can you put insulation around it to keep the water warmer? Was it worth the problems? Thanks, Dave
Re: OT bathtub to step-in
Can't help on the step-in tub, but we did put in a shower with a seat at the end. Found that Delta offers a control that will direct the water into different lines, and put a hand-held shower near the seat in addition to the regular shower head, all in about three by six feet (I have used those hand-held showers clipped to a bracket a couple of times, and they make awful regular showerheads). We haven't used the seat yet, but my bride is anticipating a hip replacement in the new year, and will no doubt need to use it then.
wooden leg
We have a roll-in shower now with various heads. She really likes bathes. Thanks, Dave
I don't have one, but I saw one on one of my Inspections. (My real job is Home Inspector.) The thing was about three and a half feet deep and you opened a door to go in and sat down on a seat. You could fill it to bathe. If I understood it correctly, it would take an enormous amount of water to fill it and you had to be in it while it was filling and draining because other wise you (obviously) could not open the door. I would want a huge water supply and water heater and drain to cut the wait time. I don't have the patience to sit there where the thing fills and drains. The one I saw had never been used, It was put in one some kind of grant program and the people did not actually want it, but it came with the program.
If you go this route I would also want the floor heavily reinforced to be sure the weight issues did not cause sagging. There are often many cut and damaged joists under bathrooms. (Plumbers are notorious for slashing any joists that are in their way.)
Re: bathtub
I helped a friend install one in his elderly parents home. The one we installed did not have either a heater or hyro-massage so we did not have to deal with special home-run GFCI circuits and code inspections (we were replacing an existing fixture in place). We did, however, have to "sister" three floor joists because, when full, the tub, without an occupant, weighed more than 200 lbs. and the 2x6 joists in the old(er) house might tend to sag under the point-load. We also put in a hand shower for rinsing as well as for cleaning the tub.
As I remember, the unit we put in took at least 75 gals. to use as a tub, more when full. That's a lot of water use compared to a regular tub bath. Aside from the concern over hot water draw, that's a lot of water to drain into a septic system all at once as you risk pushing solids into the leach field which is not a good thing. If you have sewer, that's not a concern.
Haven't heard from the friend that his parents like or dislike it as a tub. Since we designed the install as a sit-down shower as well, don't know if they even use it as a full immersion tub.
Re: bathtub
Water weighs about 8.33 pounds per gallon. 75 gallons would weigh 625 pounds. You were right to double those joists. A couple of piers underneath might have been a good idea.
Piers
Would have been a real decorating challenge since the kitchen was under the bathroom. :D
Re: Piers
Still, Piers might be better than out of the bathtub and into the frying pan.
We Checked
After the install, we put a gauge underneath, filled the tub, and measured the sag. About 1/8". I'll call that a pass.
Re: We Checked
Definitely a pass. Joists are designed to deflect either L/180 or L/240 or L/360. So even at the most rigorous L/360 and even if the joists are only ten feet long that would be 120/360 of 1/3".
Yes I put one in a few months ago. My wife has a back problem and was having a difficult time getting in and out of our old clawfoot tub. My son, grandsons and I installed it - We replaced the floor as it was easier to access the plumbing and wiring by removing the floor in the small bathroom. The tub was not hard to install, but it did require a dedicated 30 AMP 120 volt GFI circuit for the heater and pump. It is equipped with both air and water jets and has a retractable hand held shower. You do have to enter the tub then fill it and empty it prior to exiting. If she is in a hurry she just uses the shower fixture and washes up without filling the tub. She really enjoys the jets and says it helps relax her back. You do have to fill it completely to use the jets as they will not operate until a sensor detects water at the highest jet outlet (to prevent spraying water all over the bathroom).
We did not increase the size of our plumbing so it takes about 6-10 minutes for the tub to fill and about the same time to fully empty. Wife said it really isn't a problem since she is washing while it fills and cleans the tub while it empties. I purchased the tub off the internet. It was the large size and still fit in the place the clawfoot tub did. I found the prices varied tremendously - tub I purchased works great, is thick walled and found it for under $2,000 shipped. Tubs that looked similar in quality locally ran over $3 - 4 thousand.
