Router tables
Router tables
Router tables
Bob Flood
Hello: I'm going to try my hand at using a router and wonder if anyone can recommend a "worth the bucks" router table.
Re: Router tables
Re: Router tables
Tony - Memphis
My suggestion is to build your own. I bought a table top from Woodhaven many years ago and built my own base. I'm on base #2 and the top is still kickin'. Their products are very good. I upgraded to a later model fence too. I'm using a Hitachi M12 in that setup. I added a Router Raizer a while back and that is a nice product too.
I used a BenchDog router table in a class once and it was pretty slick too.
Having a table is great. I rarely use a router out of the table. There have been lots of good articles in the various woodworking mags about building a table.
Tony
Re: Router tables
Moses Yoder
Re: Router tables
Moses Yoder
I would suggest taking a router and putting a square 3/8" thick plexiglass base on it. Then take a piece of 3/4" plywood about 24" x 36" and route a hole in it that accepts the router base flush. Make an L shaped fence for it with a cutout for the bit. Clamp the table to your work bench and then clamp the fence on where you need it. After using this for a while you will know exactly what you want in a router table. Or in my case, I found out I don't want a router table and am still using the board.
Re: Router tables
Re: Router tables
nickb
I used the aluminum PC table for years (it was a gift, and it was helpfully small when I had a small shop), but moved to a Woodpeckers top with a Milwaukee 5625 mounted in a Quick Lift (both the top and the lift were bought on sale). I don't recommend the PC table, but I do recommend both the Woodpeckers table top and the lift. Both are HUGE improvements over my old set up.
I made the base (which is mobile and the right height to use my SCMS station as an outfeed table). If you have the time, I'd recommend making a base to fit your shop's needs.
Re: Router tables
Re: Router tables
Joseph Mulherin
Hello, Bob, ok, I built a new table using the plans from Norm Abram(NewYankee.com), modified it because I already had a good base, but used his ideas for the drawers and vacuum setup. Bought a new router table from Rockler along with the double switch for the router and vacuum in one, plus a new paddle switch to mount on the outside of the lefthand of the table. In using the switch mentioned, the router runs, does its work, then you shut it off, but the vacuum keeps running for 7 seconds to get rid of any scraps left...goes direct to your collector or shop vac. Very good setup
Re: Router tables
Re: Router tables
George Colonel's Workshop-Havertown PA
Good Afternoon Bob,
I believe you can make one yourself without sinking too much money into it, especially since you have not used a table before. I used a wide board initially to which I mounted the router base. Wood stock became the fence, and was held in place by clamps. I liked to work outside in my yard, so something simple was fine.
When I began to use the router more frequently I built a Norm Abrams style table/cabinet, and dropped in one of my P+C 690s to do 90% of my routing. Evolution eventually lead to a P+C 7518 mounterd in a JessEm Master Lift within my 2nd table/cabinet. Once you have determined your needs, then build your own table. I can't recommend any commercial table because I believe they are too expensive and can't provide anything more than what I have right now. I do recommend a commercial fence. I use a MCLS extruded aluminum split fence on my set up. Its accurate and inexpensive.
My first table/cabinet is still being used daily by one of my sons, who has a contracting business.
, and needed a home
Re: Router tables
Re: Router tables
Hal
I agree with the Colonel and others who advocate building your own. I built mine based on the plans presented in Bill Hylton's book Router Magic and have used it for some 10 years now. Wouldn't trade it for any commercial table on the market. At the time I lived in an area where hardwood was almost impossible to find (Bill recommends red oak) but did find some structural grade fir from a roof truss manufacturer which has served admirably. Good luck whichever route you take. Hal
Re: Router tables
Me, Too
Charles Yawn
I built one of these router tables and have been pleased with its utility, both as a router table and, with the fence removed and a improvised cover, as a mobile work table.
Charles
Re: Router tables
I hate mine
Bill Tindall
A fence that is easily adjusted and inserts that accommodate all sizes of bits are both important.
Re: Router tables
Re: Router tables
Joseph Mulherin
Hello, George, I like your table setup...it is almost exactly like the one I made from Norm's plans.
As far as buying a router lift I just received my ShopNotes magazine and there is an article in it for making your own lift which I am going to incorporate into my table later this next year.
I have decided this year to make about 6 Windsor chairs for family and friends. I have about 12 different design pictures, but my first one shall be the Comb-back chair. Will be using splats instead of spindles in the back. And there is a desk chair which I read was used by Thomas Jefferson in the writing of the Constitution....might make one of them too.
Re: Router tables
Re: Router tables
John in NM
Mine is a router screwed to a piece of 1/2" baltic birch plywood and clamped down to a piece of half finished casework (a bench with no top). Stupid simple, though the lack of nice features like a good fence and easy height adjustment limits it's use to the method of last resort :D
Re: Router tables
Re: Router tables
I built mine into an extension wing on my TS. Used two pieces of plastic laminated counter top. They were "sink cutouts" I got for nothing from a cabinet shop. Glued them together back to back to create balanced construction. Before gluing I put "T' slots at the edge and put a nut in them to allow bottling tot eh TS wing and then used screws through the rails. Cut a hole in the center and install a ledge made of hardwood. The ledge is lowered enough to allow for vertical wood screws to serve as leveling spots for the router plate. My ancient Stanley router is mounted on a piece of 1/4" Masonite and hangs in the slot. I can use the Beis Fence on the TS as a fence.
If I were doing it again I would use a bigger router to allow for half inch bits and a router raiser of some description. And if I had room in my shop I would make a separate router table. Occasionally it is not convenient to use the TS fence because you want to use the TS sometime during the setup. It would be easy to use an independent fence for the router, but then sometimes it would be in the way of the TS. On balance I like it, but Oh how I wish I had more room.
Re: Router tables
Re: Router tables
Mark
Started with a store bought metal one that a well intentioned relative gave as a gift...very difficult to set up and limited, went to the table saw wing set up, same thing, better but limited, finally built a proper 24x36 ish top as described above,bought the insert, routed a mitre slot, plus built a square adjustable fence with DC...ITS GREAT...worth doing it right the first time and it's a good project to hone your router skills.
Re: Router tables
Router work shop
del schisler
check this site which is router work shop . It is devoted to router's ect. I use mine most every day. Their is lot's of info on that site and Bob and Rick which started the router work shop http://www.routerforums.com/ and another place for router item's also . I have the router work shop table and i made the base. I wanted to get started and didn't want to build mine. click on the usa flag that will take you to the item's page http://www.oak-park.com/index.html I do not have a conection to the sites like get a discount ect. Just good stuff
Re: Router tables
Re: Router tables
AZ in Colorado Springs
I had opportunities to use the Rockler and Freud router tables before I set one up in my shop. The Freud table looks very space age, with a two part fence and finely threaded adjusters, but I found when rabbeting lids of gift boxes, that there were some dimensions that were impossible to reach. The spacing in the rows of threaded inserts for securing the fence was greater than the range of the fence adjusters -- so when I needed to advance the fence just a tad further, if I retracted the threaded adjusters and moved the fence forward one position, there's about 1/8" that I could not get to. (I suppose I could change to a different diameter straight bit, resetting the height and starting over ... yeah, right.)
The Rockler set up, on the other hand, uses slots oriented parallel to the sides in the table, and a pair of slots parallel to the front/back in the fence, so I can set the fence at any point of distance from the bit. Much better.
I had an old Skil plunge router mounted underneath and set the hieight using a hydraulic bottle jack (not optimal, but it worked), then about ten months ago I got a big Freud plunge router which allows for height adjustments through the base plate and mounted that to the Rockler table. It works great!
I made the base for the table myself -- nothing fancy, no drawers or dust collection. I just couldn't see paying $99 for a couple bucks worth of wood.
I agree with another poster who suggested going with something low-dollar to start with. Two observations: 1) you won't "know what you want" right off. It'll be easier for you to identify quirks in any set up that irritate you.
2) If you're not accustomed to incorporating a router table in your work, once you have one, it will open up a new range of options for you -- the tasks you originally wanted a router table for ... well you may find yourself doing other tasks or making different items, which will also cause you to re-think the "ultimate" or "ideal" router table set up.
Good luck!
Re: Router tables
PS
Tony - Memphis
There is a video series over at FWW on building a router table. I just watched some of it at lunch. Looks like a nice table and some good ideas there.
Tony
Re: Router tables
Re: PS
Tony - Memphis
This is my second base... I made it using mostly scraps. The project on top was one of a couple of miniature clocks I built for Christmas presents a few years ago. I used some PVC pieces for plumbing the dust collection. It works real well. The switch is from Rockler I believe.
