OT - Table saw anti-finger eater
Jim Breeden
Saw an ad couple months ago for a device similar to the Saw Stop finger sensor - very interesting. This guy had invented a similar sensor but, fitted over the top of the blade, adaptable to any saw. I sent him an email of interest but never heard back. Anybody out there remember the ad, or saw (no pun intended) the web site? Somehow I deleted it. :(
Re: OT - Table saw anti-finger eater
Re: Is this it?
Jim Breeden
:) That's it ! Thanks ! :D
Stuart Johnson
I've see the videos and think it might be an option. 1/8 of a second is fast but is it fast enough to prevent the loss of a finger or two? What type of blade brake is used?
This detection method (proximity sensing) has been used on industrial equipment for several years and is OSHA approved. I have installed it on several machines. I can't tell for sure but I think its a safe bet to say the actual "stopping" method is to apply a DC voltage to the motor. This acts like a brake and is the same technology used on SCMS and other equipment like electric mowers etc. The 1/8 second is sufficient as the "brake" is triggered before you actually touch the blade. The guard shown is an "antenna" that puts out a "field", when this field is entered by an object, the object changes the capacitance of the field and triggers the brake. I am sure it would work - but how many of us have removed the guards on our saws in order to make none through dadoes or use a sled or fixture. Without the guard installed as shown the device would not function.
Alan in Little Washington (NC)
I don't think it uses an "antenna" or "field' but has a contact strip around the base of the Lexan guard. Braking is either DC, reverse current, or something similar. The inventor is not trying to market it to individuals- he hopes to license it to a major manufacturer.
Go to the web site shown above - He DEFINITELY states he uses PROXIMITY sensing. Quote from his information - "If the operator approaches or touches the clear blade guard fence, the proximity detector -----"
It appears you are correct. I haven't been to his site in quite awhile. It sure seems like a change from what was on his site last year. I never remember "proximity" being demonstrated. The way the site says it always included proximity hints that it was either not mentioned previously or he was able increase the sensitivity of the existing unit. Also, in one of his newer (to me) videos he says it always had proximity capability but then he says he "expects" production units to incorporate both contact and proximity sensing. In any case, it is still mounted to and depends on the guard.
Seems he has added other new features like blade enclosures with different size shields, side mount, bevel attachment, and is working on mounts for scroll and bandsaws, etc. and is now stressing the "new Plug & play black box" so he is now hoping to sell licenses it to both machine manufacturers for integral units and a manufacturer who will make and sell retro-fit kits- this seems to be a new approach. He keeps evolving, gotta give him credit for that. I suspect manufacturers are waiting to see if he gets a patent.
At least with his method, you can afford to have misfires since it doesn't require a replacement brake cartridge or new blade. But what happens when you want to use a tenoning, panel, box joint, or other sort of jig that is tall? Can it be used with the popular "Gripper?"
Jim Breeden
Good question. What with all my excitement about keeping my "hot dogs" I did not think about any of the jigs I use. And the real stupid self question is, "Hey
stupid, why didn't I think of that"! Of which the Whirlwind would be usless. So
I will concede to the experts and the SS.
