feathers
feathers
feathers
Bruce, a MN Galoot
So, you mean to tell me that this is a feather? All along I just thought it was just a spline. :D
Re: feathers
I thought that was a miter key
Re: feathers
A rose by any other name
While I'm a believer in the usefulness of correct terms for things, lots of processes in every trade have multiple names.
Although I always think of a miter key as a dovetail-shaped "spline" applied the same way.
"Feather," I think, was originally British, and, particularly, referred to the splines thin enough that all you needed was a sawcut to insert them.
So, more than likely, "spline" would be the best overall term to apply, regardless of thickness of the bit of wood.
Regardless of what you call it, it's a darned useful detail.
Re: feathers
Re: A rose by any other name
Bruce, a MN Galoot
Not one of my frames have come apart since I started using them. The only problem is getting the project finished before Sunday.
At least my part is done.
Re: feathers
Thanks for clarifying
I've been using the term feather for so long that I don't even remember where I first heard it. Certainly they are miter keys, and in the most generic sense they are splines.
Re: feathers
Re: Thanks for clarifying
Jim Smith
Hello, That is a very nice looking frame, do you happen to have any more designs available that you use we could see, Thanks Jim
Re: feathers
Bruce, a MN Galoot
Thanks for the kind words, but I don't have any designs at all.
When my wife wants a frame it's her responsibility to find a design she likes. She looks on framing and crafting sites for her inspiration. Then she shows me and I tell her if I can match that with my current collection of router bits. Part of this frame was made with a beading bit I used to cut the strips for my cedar strip canoe. It's interesting to see what you can do with some ogee, round over, coving, beading and even straight bits.
Re: feathers
Dale Lenz
I've been using splines for 25+ years
Dale Lenz
mostly in the upper corners of the miters, , miter's toe. I believe the term feather or key is correct. Splines may of came from spine, back bones, as splines are used as through the joint, as on the cut surface of the miter, along the edge of two boards being jointed together, etc.
Re: feathers
Sgian Dubh
"Feather," I think, was originally British..."
More specifically the term I suspect is probably more commonly used in Scotland, which is where I first came across it, as in 'slit feathers' et al. Therefore, it would be British, but only in the same sense that all chairs are seats, but not all seats are chairs. Slainte.
