Table Saw Lubricant
Yonak
I'd like to find a good gear lube that is long-lasting and doesn't get all gunked up with sawdust.
Table Saw Lubricant
Yonak
spray teflon
What the Delta tech used.....
Bill Tindall
I attended a class many years ago on maintaining Delta machinery. The person teaching waxed the gears and slidy parts with Johnsons paste wax.
Re: Table Saw Lubricant
steve mackay
There isn't one. Clean/flush with solvent (I like "Quick-Sol") and leave it be. I learned this with the DP chuck. ANY lube will collect dust and turn to gunk. The only substance that goes near my TS is Johnson's paste wax.
I use spray graphite dry lube on the screws and gears. Parts slide, dust doesn't stick. Careful to keep it away from the belt(s)
There are several "dry" spray lubricants that do not attract dust. Usually these have one of several dry coating / lubricating materials that include Wax, graphite, Teflon, Zinc Stearate or similar material(s) carried in an evaporating - non-residual carrier. I have used several in industrial applications, but these normally are not easily available at retailers. Some easily available lubricants are DriCote, Boeshield T9 and Automotive door hinge lubes. Dry graphite is also sold as a "lock" lubricant and works well but does spread a lot of black stains on everything it touches.
Easy, inexpensive and good
Neal in San Jose
Dry lubricants designed for extreme duty are available at your local bike shop. Just ask for chain lube. Mountain bikers have a similar problem to woodworkers: They need a lube that will flow into small cracks and crannys, will stay in place, won't collect dust and dirt and won't stain everything. I've had good luck with a brand called "White Lightening", which is teflon based, but there are many others. I think I paid about $7 for a small bottle that apparently is a life-time supply for me. I use it on all sorts of things like router lifts and plunge hardware, balky chucks on drills and braces, you name it.
It smells like it has an ethanol (alcohol) carrier, which lets it flow into place then quickly evaporates leaving a dry, lubed surface. I've not had any finish or glue problems that I could attribute to it, but YMMV.
Paste Wax
Howard Acheson
Furniture paste wax is the preferred lubricant for heli gears. Use an old toothbrush to work in the wax as you crank to gears. Paste wax will clean out the old lubricant and lay down a new surface.
Paste wax is an excellent low speed, low pressure lubricant and sawdust does not stick to it.
Thomas S Stockton
Like most have said a dry lube is great, it seems like motorcycle or bike chain lube has more body and might work better.
Another key to keeping it working well is to keep the insides clean. You don't have to go crazy, but depending on use an occasional blow out with compressed air and don't let it fill with sawdust works wonders.
And overdoing it with the lubricant can also cause problems.
Tom
