Releasing Epoxy.....
I am making boxes for Christmas gifts. They are about 8"x13" by 4" tall. Have cut off about the top inch for a lid and made wooden hinges. Mortise the hinges into the backs of the boxes and glue them in with epoxy. Wanted to use colored epoxy to fill the tiny gaps around the hinges. Now that the clamps are off I discover the lids don't sit level. These boxes are in book matched pair and one is gapped up about a tenth of and inch on the front left corner and the other on the front right corner. Any chance of using a heat gun to remove the hinges and set them again? Any easy way to reverse the epoxy?
Or would you hand plane the high corner and call it good?
I used to install and change out glued in inserts in archery equipment many years ago and would just screw in a bolt, heat the bolt and pull it right out.
