lock miter joint for picture frames
eliot d
I like to make my own picture frames. Would lock miter joints be a good option for the corners? The frames are about two feet by three feet and made from 3/4 stock. Some of them will hold a glass cover, a mat, the art work, and a backing of foam core , so the frame has to be fairly strong. I don't like to use any metal. I've seen various lock miter router bits in use for drawer parts, which, of course, are much wider that 3/ 4 ". What worries me is the vertical cut with a three foot frame edge sticking straight up. I suppose the idea is to fashion some kind of jig. Is all this overkill?
Re: lock miter joint for picture frames
Don Evans
I may be misunderstanding you but I don't see how you could use that bit for frame joints. First it is designed to do 90 deg corners where a frame molding isn't done that way, UNLESS you are making something like a shadow box.
Making a frame where both pieces of wood lay flat on their widest side will not work that I can see.
I did recently purchase one of these bits, there are 2 sizes and I got the smaller one which does 3/4" thick stuff but I haven't had chance to use it yet so no practicle use with it to learn it's capabilities.
Don
Biskits
Not an option
As Don mentioned, lock miter bits are designed to rout mitered case corners and such, not wide picture frames. You'd need a 3" tall bit for that. (Yikes!) My favorite picture frame methods are biscuits for frames that are wide enough and single or double feathers for narrower frames. You can also rout grooves in the miters are use through splines. Both the splines and feathers require trimming and cleanup.
Re: lock miter joint for picture frames *LINK*
Dick Coers
If you wanted to do the joint with a router bit, the glue joint bit might be more appropriate. I've not ever used one, so can't comment on how it would work. The other ideas are good. If the stock is not too heavily profiled, a floating tenon could also be used.
glue joint bit
Phil
I've made picture frames of the size/type you describe a number of times: splines provide all the strength you need, and look great with a contrasting type of wood, or contrasting grain. I built a simple plywood jig that rides on the fence and holds the assembled frame on end to cut the slot for the splines: works great.
eliot d
I guess I didn't explain my situation very well. The width of the frame -- the edge facing the viewer -- would be 3/4", but the depth -- the dimension necessary to hold the glass, mat, etc. -- would be more , perhaps 1 1/4". So the situation is like a 1 1/4 deep drawer. I currently do use biscuits, which is fine, but suppose I don't want to see the splines on the outside? Oh, and I forgot: my router table holds two routers that are set up at right angles to each other. So, it occurs to me that I could have an easy time of it, after all, if I were willing to spring for two identical lock miter router bits. Am I still missing something?
Describe these feathers of which you speak....
I know not what they are.
I have that bit for a shaper and have used it a few times. Don't think it adds much worthwhile surface area to a long grain joint. Don't know if it would add enough area of a flat miter to overcome the "end" grain condition.
I agree with the spline idea
Bruce, a MN Galoot
and have done it on countless frames. They NEVER come apart or even open up.
Re: Describe these feathers of which you speak....
eliot d
What is it that you say you don't know about, please?
Re: Not an option
eliot d
I don't really see your point. If the frame is 3/4 " wide -- the part that faces the viewer-- and the frame is, say, 1 1/4 "deep -- the part that holds the glass, mat, etc.-- why would you need a 3" miter bit? It just looks like a 3/4" deep drawer, no?
Ellis mentioned Feathers. I wanted a description of feathers. Don't know the reference.
I think they're thinking of wider frames
John in NM
But I'm still not sure it would work, depends on how much wood is left after rabbeting for the glass, mat, and backing.
I usually do miters like this with a shooting board for a tight fit, then glue if it's molding or glue and cross nail if it's a frame. If I were going to try a more structural joint, I would use a finger joint made on the table saw and just miter the front of it. My impression though is that picture frames don't need quite as much structure as this, especially if they're framing a painting on a stretcher.
Some people call them splines *LINK*
although "spline" in a miter joint has more than one meaning, which is why I, like Ellis, prefer "feathers"*. The link below has a nice drawing and some discussion.
You can make up a jig for the tablesaw - a cradle that holds the frame as you run it past a blade sticking up just enough to make the cut - and then rip narrow strips. You can also clamp the frame in a suitable vise and make the cut with a handsaw, for which you would then, of course, use thinner strips (with a backsaw, you might well wind up with kerfs thin enough to use veneer, should you happen to have any lying about).
Glue in the strip, let the glue dry, then shave off the wood sticking out with a plane or chisel.
This is a simple addition to a miter joint, and small enough to work with a picture frame of just about any size; and it's quite strong.
*I think the term, in this meaning, is originally British.
http://www.craftsmanspace.com/knowledge/construction-of-a-miter-joint-reinforced-with-a-feather-spline.html
Feathers
Feathers are thin splines that go perpendicular to the miter. You make a little sled for the tablesaw that holds your glued frame at 45º to the table and then you make one or two passes with a relatively fine-tooth blade in each corner. Glue the feathers in, trim on the bandsaw and hand plane flush. Quick, easy, effective.
