ADVERTISE HERE - FREE TRIAL
OT Interior house paint question?
The rental house I am working on has several rooms painted with gloss or at least semi-gloss paint, Kitchens and bathrooms. I am getting mixed messages about painting over the paint. Can I just paint with more semigloss or do I have to prime with something else first?
Re: OT Interior house paint question?
You can get a pre-painting etching material - can't remember what it's called, but every paint store and good hardware stores will have it - that you just paint on with a disposable brush, then wipe down with paper towels. Works pretty well, and serves to clean the surface at the same time, although, if you've got really greasy surfaces (like around the stove), some time with TSP is advisable.
But I'll be interested in more experienced judgments on this question; I've only done but a little of this kind of work.
Nat Robison
I've painted rooms both ways and I'd be hard pressed to be able to tell which is which now. You'd probably want to at least scuff sand the walls if they have semi-gloss on them. Personally, I don't go any shinier than satin on walls since SG just seems to magnify all the defects. If you have a lot of repairs to do to the walls, I'd probably prime the whole room before painting.
Jason Roehl in Lafayette, IN
Generally, there is no need to prime over interior paint. Like Nat said, scuff-sanding isn't a bad idea--just run over it with 150 or 180 grit. Don't spend a lot of time sanding--just a few minutes per room is plenty--it's mainly to knock off any old nibs and can give the wall a little tooth for the next coat.
Don't believe any "one-coat coverage" hype and count on needing to do at least 2 coats. It's very easy to put on too little paint or to smear it (rolling or brushing) when going over a semi-gloss or gloss paint.
I spot-prime stains with shellac, unless they cover whole walls or rooms (like cigarette smoke), then I'd prime the whole area. Grease, wax and the like need to be cleaned off, but then priming may not be necessary if they are fully cleaned off.
Jason
Warren White
Almost everything we paint here at home (we are non-smokers) takes two coats. The other thing I have come not to believe is paint and primer in one. If something is purported to do two jobs in one, I have found it does neither well.
When I used Behr's paint and primer combination, I was very unhappy. I called and told them that as I was caulking around moldings the paint was coming off. They told me I should wait two weeks before putting any water on the paint. I asked if they could honestly tell me that a professional painter says to a client "I will be back in two weeks to caulk."
Bill Howatt
Is this a latex over oil-based situation? Nowdays the term semi-gloss can be used with latex where before it definitely meant oil-based.
I am a firm believer in a TSP wash particularly in a kitchen along with a quick scuff and I found that this worked well putting latex over oil-based. We had prof painters do this house a couple of years ago and they used the primer that was supposed to take care of the problem. It works but it isn't overly robust - a bit of a rough treatment and it will flake off.
Bill
