glue before or after finish?
eliot d
I'm under the impression it's best to finish boards before glue up so that glue squeeze out doesn't mar the surface and resist later finish. But suppose you just have to glue up first for some reason. Could you just try to wipe off most of the squeeze out as the piece dries and use a pre finish before finishing to still get a good finish?
Re: glue before or after finish?
I do it both ways. I glue before finishing and glue after finishing. If you glue after finishing, you have to make sure your glue surfaces are masked. If you glue before finishing, you have to make sure that your squeeze out is minimized and that you remove all glue.
I usually get out the toothbrush and the bucket of warm water and a rag to clean up after gluing. I'm usually doing my final sanding afterwards.
Yes, it is a PITA to have a little area near the joint that resists staining and finishing. I usually manage to get rid of the glue. I also do a final wipe after tack cloth with mineral spirits or a suitable solvent and a cloth. This makes sure that I can see if there are any areas that need attention (more sanding or scraping)
Don Evans
What method depends mostly on what you are making.
However, I've had very good results when using yellow glue to keep paper towels wet with warm water prepared and ready to go when the gluing starts.
As soon as the clamping is done, wipe with the towel any glue that comes out, turning the towel after every swipe is a must for good results. Never wipe over any area with part of towel that has glue on it in other words.
In some cases I don't wring out the towel very well, the excess water helps dilute the glue and wipe off is more successful.
I always use a damp cloth or towel on projects just before the final sanding in order to raise the fuz anyway to get a smoother sanding job so the above watering does no harm anyway.
On some joints you can also reduce glue squeeze by taping (blue tape) beside the joint so the glue goes on top of the tape. So as said, it depends what doing to what method, sometimes both. No matter whether using tape method or not I still have the pre prepared wet towels at hand.
Don
nickb
Consider using hide glue (liquid hide is easy and plenty strong for nearly any application for which you would use type I PVA) - it is transparent to many finishes, so all you need to do is wipe up the globs.
Personally, I've been doing trim and cabinetry lately and have been using PVA - I sand, glue-up (wait until any squeeze out is rubbery, then scrape), then finish. I tend to use hide glue for furniture.
Like others above, I do it both ways.
I like to prefinished panels in frame and panel construction so that if they expand and contact as they are wont to do, any surface exposed will be finished. To be sure those don't get glued into the frames and locked into place, I wrap them with dry cleaners bag thickness plastic or stretch wrap and leave it in place until I decide its time to remove it, sometimes after the glue is fully cored or sometimes after the frames are finished. Most of the time, I just pull them out, but if they won't come out, I just trim them close to the frame and they are invisible.
Somebody makes some chemical you can add to glue that makes it glow in a black light. Best use I know of for a black light.
Tape
David Yoho
I think any furniture project should begin with knowing what hardware and finish you'll want. Your finishing schedule should already be decided before the first chip of wood flies.
Any coloring should be done before assembly, when possible. I've found using blue painter's tape along joints before gluing greatly reduces the aftermath of squeeze-out. I use the tape both on already finished surfaces and unfinished to keep glue squeeze-out at bay.
As mentioned already, I prefer using liquid hide glue whenever possible, since it shows up clear under finishes.
It seems we spend more time drawing out or examining an existing plan and the cutting of parts than we do planning out the finishing steps and hardware selection beforehand. Both of which are what ultimately will make or break the final look of the project.
Jesse Cloud
+1 on doing it both ways.
If I have a piece with lots of details, corners, etc that will be hard to finish when assembled, I finish first. If I have a complex finishing schedule with dyes and fillers, and glazes, and topcoat, I know that fixing any flaws after assembly will be a huge PITA, so I prefinish and tape carefully.
On the other hand, if the piece is simple and I'm spraying a simple finish, why not glue up first?
Whichever way you go, before you put much work into the piece, take a scrap of the wood you will use, finish it and show it to the customer, even if its the wife. Get the customer's buy-in now or you will be sorry. DAMHIKT ;)
Same here...
John in NM
If I'm not using hide glue, the key is to catch the pva at maybe 30 min to 1 hour when it is at that nice rubbery stage. I often give the area around the joint some tung oil just before glue up, the rubbery glue pops right off the freshly oiled wood. Never could get the hang of all that washing :D
Funny thing about tape, the last shop I worked in, I had to tape the tenons since the policy was to pre-finish parts and often the finishers sent parts back to me with oily fingerprints all over the tenons.
